Toshiba 24d143db not working, standby blinking red/green
  • Chrissygizmo
    • Mar 2021
    • 108
    • United Kingdom
    Hi all , I thought I could tackle this problem without having to bother you's lot "AGAIN".
    Toshiba 24d143db (Vestel 17IPS61-3) , I thought was going to be a straightforward diode replacement , however after replacing diodes D9 (UF5402) , D10 , D12 & D25 ( SB5B0 )I'm still left with exactly the same problem, not turning on & standby light flashing red/green. I've ended up resorting to Google & I'm seeing it could be a firmware issue?
    Last edited by SMDFlea; 03-31-2021, 05:50 AM. Reason: Added "24d143db" to thread title
    • 12116
    • U.S.
    Re: Toshiba not working, standby blinking red/green
    I think you're on the right track, did you try it?
    • Chrissygizmo
      • Mar 2021
      • 108
      • United Kingdom
      To be honest, I don't know how to (firmware) . I know how to download a file to USB but what do I need to do afterwards? The screen doesn't come on so I can't go into the menu etc
      • pep2k21
        • Dec 2020
        • 35
        • Spain
        download the firmware for your model, put it in usb and plug in botom usb at tv while unpluged from main power.
        plug main power and press ok at remote control.
        should work.
        im having similar problem. i tried programing nand and now it does not blink led anymore. i read this nand usually break at this vestel boards.
        im waiting to have my own programer to try and see if i can just program my nand or order a new one
        i did a firmware brick and lost backlight. when i tried to reprogram nand lost the blinking led
        p.d. when you plug usb and plug tv to main power, led blinks faster when ok is pressed that means tv still has response to remote and should start update.
        i lost that blink light reprograming nand this last try. i think my nand is broken took too long to read and write. maybe the programer i use... dont know hope to find out soon
        • pep2k21
          • Dec 2020
          • 35
          • Spain
          you can see a bit more explained here
          https://www.badcaps.net/forum/showthread.php?t=94206
          • arizanotlari
            • Nov 2014
            • 158
            • Turkiye
            Try this : https://yadi.sk/d/C1ev1pcGjGCZcg
            • pep2k21
              • Dec 2020
              • 35
              • Spain
              Originally posted by arizanotlari
              thanks a lot! tried but mine does nothing. no blink led, only green, no control remote response no vestel app from mobile phone no from toshiba remote
              i think when firmware is corrupted, led blinks, when firmware is deleted (how i think i did) stays green i think i read this here somewhere
              • arizanotlari
                • Nov 2014
                • 158
                • Turkiye
                Re: Toshiba 24d143db not working, standby blinking red/green
                LED blinking because short circuit or corrupted firmware. If Firmware deleted led not shining.
                When upgrading firmware press and hold “ok” button until led blinking fast.
                • pep2k21
                  • Dec 2020
                  • 35
                  • Spain
                  so what means only green you know it?
                  do you still think i can do something by usb??? really? that would be great but all the times i tried all the softwares i have i had nothing no led blink, no backlight, only the green light ring i was pressing ok at remote but nothing changes on tv i also tried pushing on/off button at the side, nothing
                  • arizanotlari
                    • Nov 2014
                    • 158
                    • Turkiye
                    I think mb or pwb is faulty.
                    • pep2k21
                      • Dec 2020
                      • 35
                      • Spain
                      but i brick it, i saw this tv working with vestel firmware.
                      then i break it installing wrong firmware because vestel firmware does not work with toshiba remote
                      maybe i have broken the mainboard or power board by firmware?
                      then i did spi programing, no changed, then nand programing and i think something went wrong at this point. then tv led does not blink i want to try do it again as soon i have my own programmer
                      • arizanotlari
                        • Nov 2014
                        • 158
                        • Turkiye
                        I read first message and you write about pwb fault. That’s why I suspect pwb.
                        Vestel, toshiba or other brands including 17MBxx chassis detects rc signal when booting. Remote control type (vestel or toshiba) not important until tv boot up.
                        If standby led not blink resolder nand. If you need dump try this https://yadi.sk/d/AgEnj8vsddVttw
                        • pep2k21
                          • Dec 2020
                          • 35
                          • Spain
                          I read first message and you write about pwb fault. That's why I suspect pwb.
                          i hope next week ill have a programmer will do thank you very much
                          • arizanotlari
                            • Nov 2014
                            • 158
                            • Turkiye
                            sorry for the confusion. i not read nicknames and I replied thinking you were the person in the first message.
                            • pep2k21
                              • Dec 2020
                              • 35
                              • Spain
                              mine is already fix and working so ok for me
                              • Chrissygizmo
                                • Mar 2021
                                • 108
                                • United Kingdom
                                Thank you all for your input, before reading your replys I managed to get a bang from the power board so instead of messing about with the original pwb I rebuilt another VESTEL 17IPS61 that I had been using for components, I managed to get it back to the original state , I got impatient and passed it on ..
                                  • 12116
                                  • U.S.
                                  So what exactly was your fix pep2k21, reprogramming your original nand?
                                  • pep2k21
                                    • Dec 2020
                                    • 35
                                    • Spain
                                    reprograming nand memory with correct firmware. first time my friend did and his programmer did not worked fine. slow reading and writing but no errors. i ordered a tl866ii plus, arrived this morning and today did my first tsop soldering looks not too bad
                                    tv started as a new configuration. everything perfect
                                    but think i did a real disaster most of the times can be done with usb
                                      • 12116
                                      • U.S.
                                      Thanks.
                                      • naddaw000
                                        Toshiba 55U7863DG - green light blinking (17MB130S)
                                        by naddaw000
                                        Hello, I am trying to bring back to life my Toshiba 55U7863DG, which has never been the most reliable device - keep on annoying me with its slowness and some random start-up/shutdown issues requiring to unplug the AC. But yesterday it finally said goodbye and decided to not turn on again. Green light is blinking, I've seen this behaviour before and thought that these are some temporary whims again, but unfortunately not this time.
                                        I have checked that my TV is build based on the 17MB130S board, which seems to be quite popular and easy to buy as a used one. Still I would like to ask...
                                        12-02-2023, 01:35 PM
                                      • OMWANA1966
                                        Toshiba Satellite C850-B888 Standby Power Blinking
                                        by OMWANA1966
                                        I have the above toshiba which worked on by another technician with blinking light on the caps lock dvd rom drive and the standby power upon insertion of the charger.
                                        what i have done
                                        cleaned the mb
                                        used hot air
                                        disassembled the board but the problem is same
                                        anybody with similar problem which has been solved can assist
                                        thanks
                                        04-13-2023, 12:04 AM
                                        09-06-2024, 05:27 AM
                                      • shahnld
                                        Sony kdl 65xg9505 green amber blinking
                                        by shahnld
                                        Good Day.
                                        I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                        i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                        green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                        01-03-2024, 03:05 PM
                                        09-06-2024, 05:59 AM
