Vizio D55u-d1
+ More Options
Posts
  • wirphotos
    • Sep 2019
    • 18
    Vizio D55u-d1
    Picked this tv up from a family member who was throwing it out. I've had success with a few tv's and figured I'd take a look at it.
    I figured it was the power board based on the the standby light going out rather quickly. I ordered a board from Shop Jimmy and I'm at the same spot. Currently the standby light comes on and fades away. The light on the main board is red, when the power button it pressed it turns purple and stays purple.
    Doing the following meter readings
    L9201 (Wire runs to the LED Driver)
    (24+) Meter shows a reading and it flashes out quick
    Ground
    Ground
    CN9101 CN 9102 Power Connector from power board to Main Board
    Pin 2 Pin 1
    ON/Off DIM .07 3.29
    3D on 0.00 3.65
    Ground
    Ground
    12 VA 19.30 19.29
    12 V 19.28 19.28
    12 V 19.28 19.28
    12 V 19.27 19.28
    5V 5.11 5.11
    I'm at a lost as I replaced the power board and it made no difference. There appears to be power to the main board. There is no video, no image with flash light test and no sound.
    Begging for help! Thank you
    • 12086
    • U.S.
    Re: Vizio D55u-d1
    Need good clear straight on pictures of each board and one of the whole back as to see how they are all connected. If you have a stand alone tcon board, check for 12 volts on each side of the fuse, black neg. probe on metal chassis pos. probe on each side of fuse.
    • wirphotos
      • Sep 2019
      • 18
      Re: Vizio D55u-d1
      I will check the fuse on the t con board.
      • alfatv
        • Sep 2020
        • 353
        Re: Vizio D55u-d1
        Broken solder joints at BGA's on main board is pretty typical
        • wirphotos
          • Sep 2019
          • 18
          Re: Vizio D55u-d1
          Alright I pulled the main board out today. Ran a heat gun over the back for about 15 minutes. Let it cool and put it back in. It kicked on the backlights. I didn't notice and image appear.
          Pointing toward a main board issue now. I don't really want to put this in my oven to flow it. Doesn't appear to be many of these boards available.
            • 12086
            • U.S.
            Re: Vizio D55u-d1
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
            • jb_Bak
              by jb_Bak
              CN6401
              Pin 01 NC
              Pin 02 NC
              Pin 03 "BL_ON": 0V
              Pin 04 "N/C"
              Pin 05 "STBY 3.3V": 3.5V
              Pin 06 "GND": N/C
              Pin 07 "AC_OFF"...
              09-27-2021, 04:52 PM
