about Panasonic TNPH10771A main board replacement references
    hi,
    i´ve been searching and only found this
    https://www.badcaps.net/forum/showth...light=tnph1077
    and
    not many more info.
    i have panasonic TX-48AS640E with main board TNPH1077 1A TXN/A1JBVE
    problem was no hdmi, solution for owner was dissambly and put hot air in cpu.
    never turned on again. i know.
    i found around me for
    TX-47AS650E main board TNPH1077 1A TXN/A1DFVE
    and
    TX-55AS740E main board TNPH1077 1A TXN/A1GSVE
    i guess both post are from 5 years old maybe is there any new about how important is that reference end
    would they work for me? playing with firmware maybe?
    i ordered a programer so now i dont have to be asking my friend if he can do it for me
    thanks
    Re: about Panasonic TNPH10771A main board replacement references
    found an old ebay ad for TX-48AS640B wich says
    Compatible Model
    TX-42AS650B, TX-48AS640B
    i have near me TX-42AS650E
    would it work on mine? would you trust it? what would you do? never thought this could be this difficult to find im completely lost please
      link to usb firmware from panasonic for many models included mine, want to try when i get a new similar one?
      https://av.jpn.support.panasonic.com...uk_cis_03.html
      also i found a web that used to have them and said AV board suitable for Panasonic TX-42AS650B
      These boards can be used with different size sets.
        i found TX-48AS640B and buy it. hope it works will see
          ok. update. TX-48AS640B arrived and working fine
          only hdmi tested i dont have aerial at home.
          data from last user still in mainboard so did factory reset and now is asking if im in ireland or uk.
          anyway to change that? service menu? i still have the broken board i can read and program spi or nand
          broken board was reflowed the cpu so the rest must be fine.
            ok. finally could manage to test the aerial and everything is working normally. only tested for a couple of minutes. searches and find channels perfectly.
            TX-48AS640B main board works perfect in TX-48AS640E model.
              Sorry we couldn't be more help with this, but thank you for the follow up, it will likely be helpful to someone else.
                Hi, I have a Panasonic tx42as650b with TNPH10771A mainboard. It had hdmi problems, and I decided to reflow cpu, now it doesn't turn on. Any solutions ?
