Hitachi 50hyt62u-k tcon or driver boards ?
  • Chrissygizmo
    • Mar 2021
    • 108
    • United Kingdom
    Hi everyone.
    This is my latest problem, I have a Hitachi 50HYT62U-K tv. I was informed off the previous owner that it had been squirted with water.
    I originally thought it was going to be a right off and I would be stripping it, but I've messaged around with it and I've had a good picture on it earlier.
    I have got the problem down to either the tcon board, ribbon cable or driver/buffer board (Not sure what they are called) . I have messed around with it with hammer hands & I've managed to snap 3 of the clips that keep the ribbon cables in place on the tcon and driver boards so I've been using plastic strips to try keeping pressure on the cables , when I turn the tv on and rub along the ribbons I've had a split second of a good full screen picture. I will upload screenshots of the video I took while doing this. I would be really grateful for any help on this.
    Thanks for your time
    • 12145
    • U.S.
    Re: Hitachi 50hyt62u-k tcon or driver boards ?
    Guess the place to start would be a replacement tcon, a lot of times they're pretty reasonably priced.
    • Chrissygizmo
      • Mar 2021
      • 108
      • United Kingdom
      Hi
      Thanks for your input, I'm going to have a go at glueing down the ribbons from the top obviously so I don't get the connections dirty to see if that works first. I'm not sure if it's a good idea so I will wait for a comment first
      • Chrissygizmo
        • Mar 2021
        • 108
        • United Kingdom
        I'm going to try glueing down the ribbons to try and get even pressure over the length of the strip first, I'm just not too sure if it's a good idea incase I make the problem worse ( like I usually do ) . Just waiting on a comment first before I go ahead
        • Chrissygizmo
          • Mar 2021
          • 108
          • United Kingdom
          Sorry for repeating, I thought the first reply didn't work as I mustn't of refreshed the page ��
            • 12145
            • U.S.
            I don't think it's a good idea myself.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              If you glue them down and it works then great, but if it fails would the ribbons be in a fit state to attach to a replacement board?
              • Chrissygizmo
                • Mar 2021
                • 108
                • United Kingdom
                I have found the problem (or probably caused this problem) ... The ic on one of the ribbons that feed the screen from the tcon board has burned out, melting a small hole in the ribbon, I definitely had a full screen picture on a couple of occasions when messing around with the driver board ribbons, but I'm sure I saw a brief smoke signal while doing this, now I know the screen is kaput unless there's a way of renewing the ribbon.
                • Chrissygizmo
                  • Mar 2021
                  • 108
                  • United Kingdom
                    • 12145
                    • U.S.
                    This may work if you're up for it. Example of cof bypass there, might need to find one that gives a better step by step process but there's a lot of such videos on youtube: https://www.youtube.com/watch?v=YacI7hWWKJw
                    • Chrissygizmo
                      • Mar 2021
                      • 108
                      • United Kingdom
                      Wow I wish I had of waited , I've scrapped the tv now , I would of definitely of given this a go , never mind, thanks for the reply
                      • Chrissygizmo
                        • Mar 2021
                        • 108
                        • United Kingdom
                        Same sort of problem on JVC 49" 4K TV
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          Would be best to start a new tread since its a different TV although an identical problem.
                          • ugamazing
                            by ugamazing
                            12-17-2024, 07:05 PM
                          • osrex
                            LED DRIVER KEEPS DYING
                            by osrex
                            Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                            i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                            i have no datasheet at all for the LED lights, all i have is its length.
                            long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                            as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                            05-05-2025, 03:36 PM
                          • x_orange90_x
                            TCL 50S535 bad tcon or panel issue?
                            by x_orange90_x
                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                            03-29-2025, 11:02 PM
                          • advant
                            by advant
                            02-03-2020, 12:25 AM
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
