Busted/cracked Light diffuser plate Samsung UN55NU7100
  • lfhlaw
    • Mar 2014
    • 102
    I was attempting to replace the LED lights on an Edge-lit Samsung UN55NU7100...While removing the sheets and the light diffuser plate which already had cracks at the bottom. The plate bent(more than I'd like) and broken in half.
    1) Is it still usable if I can put in back into place
    2) or Do I have to find a replacement diffuser plate and can it be any diffuser plate from a 55" Samsung LED TV or specific to my model?
    3) can a new plate be purchased from Samsung?
  • Diah
    • Feb 2013
    • 6374
    Re: Busted/cracked Light diffuser plate Samsung UN55NU7100
    early Tv manufacture brands.. they used for 55 size and above the first hard plastic light for edge or direct LED BL a reflector from 2 pieces glued with transparent double side type. later as new model all are one pieces even for 75 size..
    if this case the crack you have.. you can use ultra transparent glue which used as glass glue by Fish aquarium .. other wise the answer to question 2 you can use any from other edge BL TV 55 size
    • brucetv
      • May 2015
      • 281
      • united states
      This is a piece of shit edge lit Tv and the led bars get so hot they can melt and even crack the diffusers. If you own a Samsung Tv with edge lit backlighting turn the backlights down to at least 10 and turn off ECO settings before this happens to you. The thick clear diffuser gets melted and leaves light bleed on the bottom. Sucks Samsung. It sits on top of the led bars to direct the light up into the diffuser. Here is a picture of how hot these get. If it is cracked it will likely show the crack when you turn it on.
      • simbaisaboy
        • May 2021
        Can a new diffuser be bought anywhere? If so where? I have 3 Samsung TV's that have this issue. Replaced all LED light strips successfully. But can't use any of them until I locate new diffusers!
        • ducky29
          • Dec 2015
          • 370
          • Europe
          Its a manufacturing problem. Still I haven't found any suppliers that have this part.
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            Even with ultra-transparent adhesive the crack WILL SHOW. The main diffuser panel is not available individually as it is part of the "panel assembly".
            This is a very common problem with the NU model series. I have a 40" NU7100 and a 65" NU7100 with the same problem and have disassembled several of this model with melted and cracked diffusers. As a result when I get a busted screen NU model Samsung with a good diffuser I keep the main diffuser and label it with the panel part number.
            You might try contacting some electronics recycling facilities in your area and see if they have a busted screen TV with working backlights and with the SAME model AND version number. If you get one, make sure the PANEL PART NUMBER is identical to yours and that the diffuser isn't melted before you install it in your TV.
            They call me......."threadkiller"
            • neilc6
              • Nov 2015
              • 1550
              That panel is typically a part that doesn't get salvaged since this model is the first edge lit model that exhibits melting along the edge. The NU design has the LEDs spaced further apart, along one edge only and they run both brighter and hotter. Probably saved Samsung $2 per TV reducing the number of LEDs in the strip. Pic 1 55NU strip. Pic 2 55ES strip (left and right)
              • DXseekerMO
                • Feb 2018
                • 1119
                • US
                LOL saved $2 per TV....and will cost them millions if the CPSC gets involved, or they get recalled! I've seen so many of these with melted diffusers I thought about filing a complaint with uncle Sam. Someone needs to methinks.
                • neilc6
                  • Nov 2015
                  • 1550
                  I just repaired a 55NU and luckily the panel was not melted and I had strips from a newer salvaged one few years ago. If there is melting, it will cause a bigger gap between the panel and LED resulting in a bright spot. On mine, one LED failed open circuit so one half was dark.
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    I think it's high time we had a thread just for this subject, so I started one here: https://www.badcaps.net/forum/showthread.php?t=96567
                    • alfatv
                      • Sep 2020
                      • 353
                      Keeping 55NU with broken screen in anticipation...
                      • noggin182
                        • Jan 2022
                        • United Kingdom
                        Have a UE43NU7020 with the same problem. Had a slightly darker strip on the TV which I left too long. Turns out one LED had gone and failed shorted. The LEDs on each of the strips seem to be wired in series, meaning the remaining ones on that half were running very hot. No pics atm, but it's really badly burned and cracked, not just the diffuser panel but also the diffuser/reflective sheet has burning on it.
                        Might try ordering new LEDs and rotating the diffuser. I was never a fan of the TV so I've replaced it now, but sure the kids will love it if I can get it in reasonable working order
                          • 12196
                          • U.S.
                          Well price sells, so how much do they cost?? Plus who are you and how do we know you can be trusted, do you sell on ebay or another trusted site?
                          • dskall
                            • Oct 2016
                            • 2905
                            • usa
                            So... you put out an ad for a product no one can find? Did I miss something here?
                            • Ukdigger
                              • May 2020
                              • 121
                              • England
                              I bought a Samsung UE43RU7100 with only a few working LEDs for £20. I ordered the new LED strips before stripping it down only to find the diffuser plate cracked at the bottom. It's still watchable but I was wondering if I could use the diffuser plate of a broken screen Samsung QE55Q60 and cut it down to 43.
                                09-07-2024, 05:50 AM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
                                Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 06:20 PM
