Toshiba 40L2400VQ No backlight but LEDs are fine
  • buchman
    • Aug 2015
    • 294
    • greece
    I have a Toshiba LED tv model number 40L2400VQ.
    I don't receive the correct voltage at the output to the LEDs.
    I disassembled the front panel and checked all leds and they are fine. Then I checked the voltage to the leds on the power board and it flactuate in milivolts.
    Tested all caps with esr meter and they are fine.
    The diodes are fine and the resistors too.
    Where should I concentrate on?
    Thanks in advance.
    Last edited by SMDFlea; 03-27-2021, 01:11 PM. Reason: Added "Toshiba 40L2400VQ" to thread title
  • Repair_dane
    • May 2020
    • 42
    • Danmark
    Re: No backlight but LEDs are fine
    If you can't find the error there is always the possibility to install a CA-288 board and run the LEDs that way
    • sigmeyer
      • Feb 2020
      • 158
      • Serbia
      Check the output transistor on the bottom of the board for shorts ,also you should be getting voltage at 2 rectifying diodes after the transformer on secondary side no matter if the led driver is working, if everything else fine then its the pwm ic is probably bad.
      • alfatv
        • Sep 2020
        • 353
        Try to measure voltage across LEDs while TV is turning on
          Thanks in advance.
          1) TV OFF, All the boards and connectors are back in place.
          2) Keep DCV (set t0 200VDC scale) meter Black probe on the chassis.
          3) Red probe on the 'ANODE' pin of the LED connector (LED connector in place).
          4) Turn on the TV while watching the meter to see what Voltage it jumps up to, then turn off the TV
          5) Red probe on the 'CATHODE' pin of the LED connector (LED connector in place) then turn on the TV and see what Voltage it jumps up to.
          BTW, what is the history of the TV?
          • buchman
            • Aug 2015
            • 294
            • greece
            Thanks for your reply guys.
            Well, when the red probe is on the ANODE pin then the voltage jump to 150V and after a second to 200V and then fluctuate between 180-200V.
            When the red probe is on CATHODE pin then the voltage rises to around 80V and then fluctuate between 60-80V.
            I bought this TV for about 15 dollars and the guy said that there is a sound but no picture. I once fixed a TV like that by replacing a few LEDs and I thought that this time would be the same but when I opened and checked the LEDs, they were all fine.
            • buchman
              • Aug 2015
              • 294
              • greece
              The voltage flactuate very fast between 70V to -100V.
              What does that mean when the voltage goes to a negative zone?
              • angelos
                • Dec 2012
                • 573
                • South Africa
                It sounds to me like a backlight strip issue. Remember that if there is a break anywhere in the series LED circuit like a loose connection the tv's circuitry picks that up and shuts down the voltage.. I had that the plug where the voltage connects on the strip was loose.
                Another abnormality is that you could have the led current shorting to chassis through a stray path. I had carbon build up once that caused this kind of issue. What I would do in that case is loosen all the strips and let them lie on a book (insulative) and then start up and see if the backlights come up. If they do then for sure you have a short to ground somewhere in the strip circuit.
                • angelos
                  • Dec 2012
                  • 573
                  • South Africa
                  If you have a LED tester you can bias each strip one by one and note at which voltage the strip drives. If there is one that has a different voltage from the others then you can check for a fault on that strip.
                  • buchman
                    • Aug 2015
                    • 294
                    • greece
                    I checked each LED strip with a power supply and they all work fine
                    • R_J
                      • 9624
                      Did EACH led light up at the same brightness as the others in the strip? Did you have the lcd screen removed when you tested the strips with the power supply?
                      Remember that the TV power supply led circuit closely monitors the current and will shut down when it sees too much current drawn by the strip (maybe one shorted led)
                      • buchman
                        • Aug 2015
                        • 294
                        • greece
                        Yes I removed the LCD screen. Seems like all leds light up the same brightness
                        • Diah
                          • Feb 2013
                          • 6588
                          LED units for backlight.. never examined if they light on or not... you should test each one with digital meter at diode test to exam the forward currents ziner diode which built in the LED not shorted or open.
                          • buchman
                            • Aug 2015
                            • 294
                            • greece
                            Just checked with the LED plug off and the result is the same.
                            • R_J
                              • 9624
                              The VOLTAGE reading is the same with the led plug connected or not connected? that means there is an open in the led string.
                              • buchman
                                • Aug 2015
                                • 294
                                • greece
                                I checked the voltage on the connector that is located on the power supply board with the LED plug on and off and the voltage on that connector that located on the power supply board is still fluctuate.
                                • pni
                                  Backlight panel diffuser melt by backlight leds broken
                                  by pni
                                  Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                                  10-12-2025, 12:08 AM
                                • triplefour
                                  by triplefour
                                  09-13-2023, 10:43 PM
                                • hollox123
                                  ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                  by hollox123
                                  Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                  1. Laptop keyboard doesn't work
                                  2. The backlight on the laptop keyboard doesn't work
                                  3. The x2 side LEDs (red) on the laptop don't work
                                  The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                  I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                  But I am strongly aiming that it is somehow a BIOS-related problem,...
                                  05-11-2025, 08:05 AM
                                • signal.quest
                                  Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                  by signal.quest
                                  I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                  03-17-2024, 10:14 AM
                                • Boyxba
                                  TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
                                  by Boyxba
                                  I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
                                  05-13-2023, 11:47 AM
