Telefunken Model: D32F289M4CWI has sound but no picture
  • samtron786
    • Aug 2016
    • 170
    • germany
    Hi
    Telefunken Model: D32F289M4CWI has sound but no picture, I checked 2 LED strips, they are all OK after the TV has been switched on, a short flash occurs and stays on but no light or picture with a flashlight can I do something see
    The power supply is VESTEL 17IPS62
    Vestel 17 MB 211S Mainboard
    Many Thanks
  • samtron786
    • Aug 2016
    • 170
    • germany
    Re: Telefunken Model: D32F289M4CWI has sound but no picture
    when I restart the TV it flashes 7 times and turns off flashes 13 times
    i need the schematic
    many thanks
    • arizanotlari
      • Nov 2014
      • 158
      • Turkiye
      many thanks
      Circuit diagram : https://drive.google.com/open?id=13R...HLqH0P-XYLWcMH
      detach lvds cable and turning on again.
      https://www.badcaps.net
      • petehall347
        • Jan 2015
        • 4438
        https://www.youtube.com/watch?v=uPI1QBE0CxI
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • jchang
          Samsung UN70NU6900F no picture and no sound
          by jchang
          Hi all
          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
          Symptom:
          No picture no sound.
          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
          No sound at all.
          What I tried:
          1. I tried unplugging the left or right ribbon...
          01-09-2023, 06:28 PM
        • freccia
          Vestel 42 inch VES420UNDL no picture, backlight ok, sound ok
          by freccia
          I have a Finlux/Vestel Led Tv with the following fault and cannot reason from where the fault is. Fault is:
          Sound ok, Backlight ok, Picture nothing but colour vertical lines. power supply vestel 17 IPS 71, main board 17MB82S
          Checked 12V on tcon on fuse ok.
          Checked 12v and 24v on power supply ok.
          Volume works. removed l left ribbon cable no picture white on half, and same with right one.
          Any idea from where I can start please?
          Any help appreciated please....
          01-09-2022, 05:14 AM
        • nickgronk
          iMac PowerPC G4 very low sound • Sunflower Model
          by nickgronk
          Just picked up an iMac powerpc for $1 at auction. changed pram. This is working. Problem, barely any sound. I have everything cranked up in software, reset nvram/pram - nada. I do get sound ONLY if I plug in a powered speakers in headphone port. I do not get the startup bong.
          I get almost no sound with normal headphones. I mean, you can barely hear it. Took the board out and by eye found these 2 inductors broken. Not sure if they are for sound. Speaker is also plugged in and I tried a normal pc speaker in its place - still zilch. Are these inductors the culprit?
          I cannot find any schematics...
          08-05-2024, 07:04 AM
