TV sticks on radio channels.
  • kandj1@talktalk.net
    Keithontheheath
    • Sep 2015
    • 8
    I have a strange one with a Technika LED19-248COMI...
    The set tunes in all channels, which is great, but if I select a radio channel, e.g. 726 Radio Solent, then, if after listening I select a TV channel, e.g. 1 BBC1, it just stays on the radio channel. Even switching the set off and on doesn't cure it, as the radio channel just comes back on. The only way I have found to get TV channels back is to retune, which is a pain!
    Any ideas, please?
  • Diah
    • Feb 2013
    • 6438
    Re: TV sticks on radio channels.
    many those small size TV the Chinese firmware very funny.
    so if you dont have on the remote control TV/radio to switch on.. call the channel list and with < or > switch between all channel and TV channel..
    • Diah
      • Feb 2013
      • 6438
      • rustinjust
        Advice needed-Technika 32-207 works but sticks on channel,won’t change channels ok
        by rustinjust
        My tv will work for a while and change channels with the remote as it should but then it will stick on one channel only and work ok but it won't change channels. I have tried unplugging it for hours and whilst unplugged pressing the power button on the tv to reset it.
        The volume button on the remote still works but it just won't change channels once it decides to stick on one channel
        It has built in basic freeview tv here in the uk, I've tried doing an automatic search to reset the tv but nothing works.
        I have to turn the tv off and then on again with...
        09-28-2023, 12:23 PM
      • shelby5041
        clock radio / radio lifespan?
        by shelby5041
        hi
        ive got a modern digital clock radio approx 15yrs old
        my question is how long can a clock radio or a simple radio last ss farcas operating hours?
        since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
        the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
        it uses very little power just a few watts i would imagine that may have something...
        09-14-2024, 03:30 AM
      • dicky96
        Hitachi V19B01922 Channel Tune problem
        by dicky96
        Hi Guys
        I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
        He also has an LG TV, so three screens in the bar
        I installed three Satlink ST-6503 DVB-T Modulators
        This model https://www.aliexpress.com/item/32916553905.html
        These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
        02-09-2023, 09:20 AM
      • UserXP
        Vintage SONY Digital Clock Radio ICF-C12W no audio
        by UserXP
        Dear all,
        I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
        i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
        My question is, do you know of this brand of capacitors and how bad are...
        07-21-2025, 08:35 AM
      • praveenramavath
        Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
        by praveenramavath
        Hello All,
        I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
        https://www.hifivision.com/threads/m...-screen.98243/
        Troubleshooting Summary: Majority Internet Radio - Flash Chip
        04-26-2025, 09:08 AM
