TOSHIBA 40L3453DB red-green blinking light
  • Diah
    • Feb 2013
    • 6500
    Re: TOSHIBA 40L3453DB red-green blinking light
    use the first file first at POST #4 but now you need to add # comment to the txt file of all Mboot section to avoid writing any things to this shit U10
    • Fergal22
      • Feb 2021
      • 50
      • United Kingdom
      #42
      Hi can you take a look at it to see if i have # out all the write parts please
      if yes do i just do the upgrade procedure with usb stick and remote?
      • Diah
        • Feb 2013
        • 6500
        its good.... do it same way you did before when it brick
        • Fergal22
          • Feb 2021
          • 50
          • United Kingdom
          #44
          Hi i tried 2 different usb sticks with same firmware, hold ok button on RC, power on tv but blinking red/green light stays the same it does not speed up
          • Diah
            • Feb 2013
            • 6500
            try the second firmware, but do the same things to add #comment
            also try the the mega download firmware i gave to you..
            • Fergal22
              • Feb 2021
              • 50
              • United Kingdom
              #46
              ok will do
              • Fergal22
                • Feb 2021
                • 50
                • United Kingdom
                #47
                Ok tried all 3 firmware again but no change, i don't get the red/green blinking fast light
                it just stays blinking red/green all the time
                • Diah
                  • Feb 2013
                  • 6500
                  do you have now grey screen ( backlight come on ) as you wrote at yours first post ???
                  • Fergal22
                    • Feb 2021
                    • 50
                    • United Kingdom
                    #49
                    No screen is black no back light
                    • Diah
                      • Feb 2013
                      • 6500
                      but before as first post you have backlight on ( grey screen ) with blinking right? or it was as now !!
                      • Fergal22
                        • Feb 2021
                        • 50
                        • United Kingdom
                        #51
                        I definitely had grey screen before i tried do anything at all to it
                        now just getting red/green blinking light and black screen
                        • Diah
                          • Feb 2013
                          • 6500
                          okay, this mean the U10 firmware didn't matched.. so response to RC... try the second flash file.. you need to try any dump found for 17mb95 boards with vestel panel.. when we get back as yours first post we can handle it again..
                          • Fergal22
                            • Feb 2021
                            • 50
                            • United Kingdom
                            #53
                            Ok i will come back when i have grey screen
                            Thankyou for all your advice
                            PS i tried using buttons on side panel as well
                            • Diah
                              • Feb 2013
                              • 6500
                              if you have i8 mini air mouse keyboards good candidate for such condition too
                              • Fergal22
                                • Feb 2021
                                • 50
                                • United Kingdom
                                #55
                                I do but this tv only has 1 usb slot
                                • Diah
                                  • Feb 2013
                                  • 6500
                                  then you can use USB 2.0 Hub , you will have 4 slots LOL
                                  BTW: what you need are on this web... need to register first
                                  • Fergal22
                                    • Feb 2021
                                    • 50
                                    • United Kingdom
                                    #57
                                    I don't have one unfortunately
                                    that link takes me nowhere as the first part is missing
                                    • Diah
                                      • Feb 2013
                                      • 6500
                                      its blocked over here
                                      google after the last dump/lcd_pdp_tv/toshiba/toshiba_40l3453db_shassi_main_board_17mb95/238-1-0-27521
                                      • Fergal22
                                        • Feb 2021
                                        • 50
                                        • United Kingdom
                                        #59
                                        I have found it and registered but wants me to take a test before i can get the file but i do not have the knowledge to answer the questions,
                                        cant find the answers on google either
                                        • Diah
                                          • Feb 2013
                                          • 6500
                                          leave it.. its really spam side... this why its blocked over here.... try your own to flash u10 again... maybe with the dump you get from the chips.. or other... now you how to flash..
                                          also check friends round you if some one own usb hub... i never thought you have programmer and this tiny things you dont owned
                                            09-06-2024, 05:27 AM
                                            09-06-2024, 05:59 AM
                                            09-06-2024, 05:33 AM
