Samsung 51d530 lava lamp problem
  • momola
    • Jan 2021
    • 9
    • usa
    Hello all,
    I bought a used samsung 51D530 to replace another tv that broke. The picture looks more or less ok except for the upper right part of the screen. It has a wavy purple lava lamp effect that shimmer and waves partly into the screen towards the middle. Sometimes it is only about 10% of the way in, and sometimes it makes its way half way in toward the center. I also notice the upper right quarter of the screen sometimes seems to shimmer slightly on white backgrounds.
    Could this be a bad X-main board? Could this be a bad main board? I can't seem to figure it out even after reading through these forums.
    Randolph
  • nomoresonys
    • 12276
    • U.S.
    Re: Samsung 51d530 lava lamp problem
    Can you post as picture of the "lava lamp effect"?
    • momola
      • Jan 2021
      • 9
      • usa
      I will try and post a picture if I can get a decent shot with my phone
      • momola
        • Jan 2021
        • 9
        • usa
        I tried to take a picture with my phone, but it did not show up in the pictures.
        The last two days it has been more like a wide not solid flashing purple haze that flashes or shimmers that extends towards the middle of the screen and then retreats over and over again.
        I'm sorry I can't explain it better.
        Randolph
        • nomoresonys
          • 12276
          • U.S.
          Is it something like this? but DO NOT EVER do what he did, that's not how you fix it:
          https://www.youtube.com/watch?v=_KsGoE8ehnY
          • momola
            • Jan 2021
            • 9
            • usa
            No, nothing like that. I can still watch the tv no problem. It is a only a 10% horizontal stripe from the upper right that does it. And it comes and goes. It might be there for 20 seconds, than gone for 20 seconds, then back for 20, then gone for 20. It also travels from only a small strip on the upper right to half-way into the pannel.
            Randolph
            • nomoresonys
              • 12276
              • U.S.
              Ok, I didn't realize this was a plasma set, better left to the plasma pros here.
              • momola
                • Jan 2021
                • 9
                • usa
                I noticed when this happens if a pause the video for a second and then start the video again it goes away. Strange huh. I was thinking since it not on the screen 100% of the time it could be possible the main board?
                  09-07-2024, 05:50 AM
                • howardc64
                  Samsung UN55JU650DF network/streaming problem
                  by howardc64
                  Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                  This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                  07-09-2025, 12:44 PM
                • alro7779
                  Samsung UN55MU6103F video problem; has colored stripes on the display
                  by alro7779
                  Hello, everyone!
                  A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                  09-27-2025, 11:29 PM
                  09-06-2024, 11:40 PM
