Can someone help me identify value of this component from Sony Tcon board. Thanks
  • gersrt
    • Jan 2021
    • 22
    • Ireland
    Hi
    bit of a long shot, but here is the challenge lol. Can anyone help with the value of this regulator ic I have circled in the attached picture. Markings cant really be read but what I can read is its marked 50 in the small circle in the middle of the ic. I need to change this component but cant figure out the value and what to change it with.
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Can someone help me identify value of this component from Sony Tcon board. Thanks
    Is there another one of these components on the Tcon that could help you identify it?
    • gersrt
      • Jan 2021
      • 22
      • Ireland
      Yeah 3 or 4, but same thing nothing readable written on them. Thanks
        • 12331
        • U.S.
        What's the full model number of the tv?
        • diif
          • Feb 2014
          • 6978
          • England
          If you can't read the markings buy yourself a jeweler's loupe or pocket microscope off ebay.
          • gersrt
            • Jan 2021
            • 22
            • Ireland
            Hi its kdl-46hx823 the tcon board number is 1-883-893-11
            It's used on 4 or 5 sony models.
              The way it is connected, it looks like MOSFET.
              • petehall347
                • Jan 2015
                • 4450
                • United Kingdom
                take a closer pic that shows the writing
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  It's a pity you don't have one of those cheap component testers / identifier and then you could check one of the other identical devices.
                  https://tinyurl.com/ypmzgrrw
                    • 12331
                    • U.S.
                    it's a pity you don't have one of those cheap component testers / identifier and then you could check one of the other identical devices.
                    +10
                    • Daren87
                      Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                      by Daren87
                      I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                      08-13-2023, 03:25 PM
                    • iglitare
                      by iglitare
                      09-04-2025, 07:13 AM
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
                    • rimwall
                      Sony KD-65x7500D - double image - Tcon or Panel?
                      by rimwall
                      This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                      I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                      11-18-2025, 02:09 AM
                    • thelankanguy
                      Sony KD-55X9000F TCON Issue
                      by thelankanguy
                      The TV shows a black screen with no image.
                      TCON ribbon connectors were disconnected individually for image and there was no half image even.
                      Later both ribbons were disconnected and TCON voltages were tested.
                      12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                      There is also a short to ground in this circled inductor.
                      Is this a TCON issue or something else ?...
                      12-13-2024, 12:27 AM
