UE40ES6300 how to remove screen?
  • Newbie123
    • Oct 2015
    • 58
    • uk
    Hi all i had a UE40ES6300 slim edgelit led tv yesterday with a cracked screen when i took it apart the screen was welded to the tape/rubber underneath the screen.
    Of course the screen was cracked and i was only harvesting the parts for ebay sale so this was not a problem this time if i damaged the screen further..
    Can anybody please tell me if i could of moved the screen and kept the plastic frame underneath it in one piece?.
    If not what tool would you recommend to separate screens?
    I know a lot of newer screens are glued down many thanks in advance if you could add pictures of the tools you use and explain the method i would be very grateful cheers!.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: UE40ES6300 how to remove screen?
    Have a look here. https://www.badcaps.net/forum/showth...t=Glued+screen
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • Maxpower3
      Hantek 365 Remove screen on startup
      by Maxpower3
      every time I open the tool, I have the screen that appears
      and I am always in a hurry to use it so I click and it automatically sends me a link to the manufacturer.
      It annoys me lol.
      2 solutions to remove it.
      Either you remove pic.bmp and it no longer appears so no more links when clicking.
      hope this helps users...
      01-15-2025, 03:24 PM
    • spice_disc
      Vizio TV M50-C1 reboot cycle and static on screen
      by spice_disc
      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
      09-08-2024, 02:37 PM
    • ipatch
      ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
      by ipatch
      i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
      08-24-2024, 02:36 PM
    • FreakyMex
      Trouble to identify part (Lunii screen) for replacement
      by FreakyMex
      Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
      I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
      02-17-2025, 01:16 AM
