HiSense 50CU6000 screen goes black after a few seconds
  • MikeRWK
    replied
    Re: HiSense 50CU6000 screen goes black after a few seconds
    Originally posted by Diah
    if you can fix the traces.. you will be hero... then with replacement t-con yours set will back to life
    I'll try to fix it sometime but for now I've had enough.
  • Diah
    replied
    Originally posted by MikeRWK
    I'm done. Whatever happened to the tcon it gets hot as fuck now, so even if i fix the traces on the screen they'll just burn up again.
  • MikeRWK
    replied
    Ok, Dr. Frankenstein, let's re-prep the patient for surgery.
    replied
  • MikeRWK
    replied
    seam you never listen to other Man... the first point i write to screw the t-con to chassis..
    dont do any things more its not bad... remove the speaker and metal cover of the panel boards let see where it damage... its look just lines not parts burning
    I thought I had it screwed down already.
  • MikeRWK
    replied
    When the tcon lost ground it found it somewhere else...
  • Diah
    replied
    I swapped the ribbon cable from the other side and part of the screens circuit board caught fire and a trace burnt, she's fucked. I think I fucked something up when the tcon came off the the tv while it was powered.
    sad.
  • MikeRWK
    replied
    She's done.
    replied
    Oh crap.
    replied
    You mean you only get a quarter now, when last exact setup gave you half a good display?
  • MikeRWK
    replied
    what hell this photo ???
    did you broken the ribbon cable... it look you have short on the ribbon cable
  • Diah
    replied
  • MikeRWK
    replied
    Might be a candidate for "tape cut-off method"
    Forgot to attach a pic last time. Also when the tcon came of the side of the screen by the power buttons got pretty hot. I'm guessing I fucked it, not sure why I bought a broken tv anyways when I usually get them for free.
    replied
    This bright young man nailed it down to the exact faulty line: https://www.youtube.com/watch?v=pfrRhw7-ZII
    replied
  • MikeRWK
    replied
    you need to do exact point after point with out signal.
    1- you need screw the t_CON to chassis al least 2 screw 1 at each side
    2- disconnect only the ribbon as you did first time ( the left front side should display picture and other side will be white.... so you can see the menu setting when you call it )
    3- call the menu setting and go down to audio setting you need to inter service menu 1-9-6-9
    under first page there are some things clear chip ... if you are not sure.. upload photo to tell you which need to initial the chip ( hard reset ) the set will go standby... plug it from wall socket and put the ribbon back then plug in and start the set... tell the result
    I can't see the menu now I'm only getting a quarter of the screen on that side. I didn't notice before I didnt have the tcon screwed down and it lost ground, did I damage something?
  • Diah
    replied
    Sorry I missed that part. The tv will work with only one cable plugged into the tcon, either side works. There is also a horizontal line on one side that I've taken a pic of, the tv's menu items and stuff have lines coming from them.
    replied
    Man ...i asked you to feed signal.. we want to see when there are signal load on the t-con and panel.... also you need to do same way disconnect the other side
    +1, what is the result?
  • MikeRWK
    replied
    replied
    ^Yep, I posted right before he said he got it to stay on after tcon disconnect.
  • HTR-Informatique
    by HTR-Informatique
    02-09-2025, 06:51 AM
  • howardc64
    by howardc64
    Problem
    08-04-2024, 10:36 PM
  • VcemPzd
    Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
    by VcemPzd
    Hello everyone !
    My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
    04-28-2025, 10:14 AM
  • DaniK
    Acer Aspire E5-574-52RH - black screen
    by DaniK
    I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
    Laptop came in for a SSD upgrade, took everything apart to install the SSD.
    Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
    Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
    The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
    Symptoms are:
    - random black screen after displaying Acer logo...
    02-21-2024, 06:27 AM
  • EUWest
    Hisense H49M3000 PSU buzzing + Black screen after 20min
    by EUWest
    Hey Folks just got another Hisense with an unusual Problem.
    After plugging in its starts buzzing on the cold side. Could not located it 100%, but seems like transformer/capacitor.
    TV has 1 horizontal Line, often static. After 10min screen gets flickering and after about 20min screen gets Black while Sound is on. After turning off and on screen appears back for about 5min and then went Black again.
    I checked LED Voltage:
    While Screen is on about 115v
    While Screen is Black also about 115v
    LED Connection unplugged also 115v
    09-12-2021, 11:09 AM
