Re: Insignia NS-39L700A12 backlight transformer high pitched wine
There could be a fault with the led's causing the problem, carefully remove the lcd panel & diffusers and see if there are some bad led's.
I've decided to scrap the tv it was free anyways.Leave a comment:
L601 is NOT a transformer, it is just a coil (inductor) In this case it is used to boost the led voltage, Is the base supply voltage ok and clean? If the supply is not filtered properly, there can be a beat frequency between the main supply transformer frequency and the led driver frequency.
Or it could just be due to loose windings or cracked core in the coil. Are the backlights ok and does the whine change with if you change the backlight level?Leave a comment:
Or it could just be due to loose windings or cracked core in the coil. Are the backlights ok and does the whine change with if you change the backlight level?Last edited by R_J; 01-25-2021, 04:14 PM.Leave a comment:
I replaced all the electrolytic caps with known good ones and it's still got the high pitched noise coming from the transformer. What causes transformer whine?Leave a comment:
18 volts is fine for the main & pfc ic's The emitter voltage will be higher in standby because the transistor is turned off. So is the vcc voltage in standby 21.5v or is iI changing? In standby, N503 is in burst mode so the vcc voltage could be changing, or the capacitor for that voltage is bad. The standby ic also uses this voltage but only requires it to be around 15 volts (stop voltage is 8.1v) in standbyLast edited by R_J; 01-25-2021, 12:55 PM.Leave a comment:
Should the voltage on the emitter fluctuate like this with the tv off? https://streamable.com/x4o0z1Leave a comment:
If the 18v is stable then it should be ok, if it is slow to build up to 18v then there is a problem. To be sure of the voltage I would need the part numbers on N504 & N501Leave a comment:
I checked the voltages on the transistor the pic with the meter illuminated is Emitter and the other pic is Collector voltage. I replaced all the capacitors besides 4 that I don't have at the moment and it seems more likely to power up when its first plugged in but its still the same.
It's occurred to me I'm going to need a capacitance meter to make things easier in the future.Leave a comment:
I usually pull them from working tvs with broken screens, which is why I really need to buy a capacitance meter.Leave a comment:
It's occurred to me I'm going to need a capacitance meter to make things easier in the future.Last edited by nomoresonys; 01-24-2021, 06:13 PM.Leave a comment:
If the transistor, which I am guessing is V503 was open, the tv would not operate at all. It is best to check the emitter and collector voltage when the tv is turned ON, Using HOT GROUND. this will give tell you if you have proper vcc voltage for the primary ic's to operate.
The main filter voltage going from 160vdc to 200vdc indicates the pfc circuit is working. I would replace those small electrolytics in the primary circuits, they can go weak and cause this type of problem.
By dead I meant open, I tested it according to this video https://youtu.be/GFitoQSbLvA?t=302 , while I don't understand the language I see what he's doing.
The main filter voltage going from 160vdc to 200vdc indicates the pfc circuit is working. I would replace those small electrolytics in the primary circuits, they can go weak and cause this type of problem.Last edited by R_J; 01-24-2021, 02:23 PM.Leave a comment:
Agree, either there's some doming or it's one hellofa optical illusion.Leave a comment:
Is this V503???? Explain "dead", shorted, open, leaky ? If it is this transistor it is the vcc switch for the main and pfc ic's
Slow turn on is likely due to bad caps, C536 & C531, standby startup cap. & vcc supply cap.
C519 & C520 are vcc & start cap for the main ic N504
Have you checked the voltage across the main filter C517? check it in standby and then again when the tv is turned on. this voltage should be 160vdc in standby and go up to around (200vdc?) when tv is on.Leave a comment:
Standby is 162-163 and when I try and power it up it goes up to 206 and settles at 199 while hissing. Then it goes crazy and the voltage fluctuates https://streamable.com/wjr9s6 I was pressing the volume buttons in the video.
Also is this resistor supposed to be hot to the touch?Leave a comment:
by ohrenHello!
I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
Measured voltages with no load:
After rectifier diodes
12V: 6.17 V
5V: 5.67 V
Secondary transformer pins AC measurement (really don't know if this says anything)
12V: 2-2.5 V
5V: 1.04 V
I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,... -
by JDCIssue: Funai FW55D25F - High Pitched Squeal Upon Power-on.
Solution: Replace C3208 and C3209 on main board. These are surface mounted capacitors. Values unknown so I just used same physical size capacitors from a donor board. -
by mikey5791Hi all,
Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
My questions are
1. How do i test to see if the transformer is in good working condition?
2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
Hope you guys understand what i was asking. My intention is... -
by oldmanhouseHi folks, I have an issue with my 7 year old Panasonic TX-L50B6B that has appeared within the last few days.
The symptoms are:
- A high pitched "buzzing" / "whining" noise coming from the TV when it is turned on. There is no noise during standby, and the noise persists with all AV connections removed.
- There are noticable horizontal lines in the picture. Upon closer inspection it looks like every few rows of pixels are dead/black.
Attached is a close-up of the picture in "test mode", to demonstrate the rows of black lines.
by BriesmithI have a blown smps and I am looking for some reassurance as to the amount of diagnosis I have to do. It blew the instant I plugged it in not under any load.
As you can see from the attached pix, the damage is located around the main or bulk capacitor (since removed for testing) and the resistor array/network that drives it (the bunch of SMD components to the left of the YAMAHA YC775 AMPS logo). The burn mark on the frame clearly shows the pins of the capacitor. And, for the avoidance of doubt, there is no way the board could have contacted the frame, it was correctly mounted on... - Loading...
