Sony KDL-40XBR Vertical lines
  • Dingopup
    • May 2020
    Has any seen this Vertical lines across the screen on all input sources but the Menu and Saved Wallpaper (Painting) stored in the tv display fine.
    The Main logic board has two Video processing chips the
    CXD4716BGB and DRC-MFv3 I cant work out witch one is the problem.
    Any help would be great
    just a shame to through away a nice Unit
    Dingopup
  • nomoresonys
    • 12322
    • U.S.
    Re: Sony KDL-40XBR Vertical lines
    What's the full model number KDL-40XBR? 4? 5? ?
    • Dingopup
      • May 2020
      Hi there thanks for replying
      KDL-40XBR45
      • ivtec
        • Dec 2008
        • 1967
        https://www.youtube.com/watch?v=qK_RB5ddgHw
        • Dingopup
          • May 2020
          Hi Ivtec
          Thanks for that but my problem is a bit different i can still see the picture displaying content and the menu and photos store in the TV are prefect.
          • visionbluedemon
            Help. Sony kd-65x85dj vertical lines
            by visionbluedemon
            First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
            Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
            tried blocking LC lines too, but same results
            is it lcd panel issue or tcon board issue?...
            07-25-2025, 04:56 AM
          • gpo23
            Sony KDL-40V3000 - Vertical lines
            by gpo23
            i order a t-con because i had bad colors on my SONY KDL-40V3000 :
            With the new t-con the color are good but there are vertical lines on all the screen :
            I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
            Is there a way to fix the vertical lines on the new t-con ?
            Thank you for your help
            gpo23...
            10-04-2023, 09:11 AM
          • Stanley1843
            Screen Display Vertical Multicolor Lines
            by Stanley1843
            Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
            06-29-2024, 11:54 AM
          • noisykid
            Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
            by noisykid
            5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
            12-30-2024, 07:15 PM
          • dustman1747
            Sony XBR-65X900H vertical lines
            by dustman1747
            I have acquired a Sony XBR-65X900H to try and fix. It probably was a complete no power situation. The main board was replaced and the TV started turning on. I now have start sounds and backlights, but no image. I've replaced the t-con with no improvement. Cables all appear to be ok and seated properly. The TV took a firmware update and hard reset but neither helped.
            Using the tape trick I can get both side to display combinations of colored vertical lines. There is no change in the stripes and the pattern always appears the same. If I add additional tape strips I can get the screen...
            09-18-2023, 09:05 PM
