Panasonic TX-L42U2E 7 blinks SUB3.3V_SENSE_SOS
  • unxtres
    • Aug 2017
    • 20
    Hello
    TV blinks 7 times
    aboard - TNP8EA106
    PBoard - TNP8EP103
    replaced A6059H (IC802) on PBOARD and also new flashed nand +eeproms on ABOARD
    NAND=IC8921 - H27U1G8F2BTR
    IC1101-24C16
    IC8950-24C32
    tv still flashes there is only 5v on pboard
    maybe someone got experience with similar problem
    service manual attached.
  • unxtres
    • Aug 2017
    • 20
    Re: Panasonic TX-L42U2E 7 blinks SUB3.3V_SENSE_SOS
    Because there is a two relays on pboard 5v trigger them i`ve decided to check them, both was fine when powered with 5v and now when i turn on tv it goes stady green than green start flashes quickly and goes to 10 red blinks
    for few moments there are 24 and 12 on board so i can assume pboard is fine and there is a problem on main.
    Just reheated cpu to see if this will make any changes.
    Edit:
    CPU heating gives nothing red light flash 10 times
    • Andre Gilbert
      by Andre Gilbert
      11-20-2024, 08:52 PM
    • Biruslapio
      Panasonic P58V11B 8 and 12 blinks error "fix"
      by Biruslapio
      Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
      Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
      04-13-2021, 07:13 AM
    • jm1234
      Panasonic plasma TX-P42ST50 - 6 blinks
      by jm1234
      anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
      It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
      I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
      I checked that board for any obvious faults...
      05-22-2024, 06:59 AM
    • Alicat
      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
      by Alicat
      Stopped by this site trying to fix my parents Panasonic Plasma TV.
      Model number is TH-50PZ85U
      Power comes on and the red power light stays on solid.
      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
      I also hear a few clicks.
      I also think my parents said there was a thunderstorm and the TV failed after that.
      Section 6 in the service manual talks about power and no screen,...
      10-30-2024, 10:09 AM
    • CrewmanRedShirt
      Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
      by CrewmanRedShirt
      Hello all,
      As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
      07-13-2024, 11:02 AM
