Sony KDL-70W850B T-CON problem
  • hmendez86
    • Jun 2015
    • 344
    • united states
    Re: Sony KDL-70W850B T-CON problem
    I did install and did same thing with original board
    • hmendez86
      • Jun 2015
      • 344
      • united states
      • Diah
        • Feb 2013
        • 6363
        how many days / weeks your TV worked after you replace the mainboards ???
        • nomoresonys
          • 12156
          • U.S.
          Maybe check for bad solder joints on that connector there.
          • nomoresonys
            • 12156
            • U.S.
            Try unplug tv from power, unhook cable from powerboard to mainboard, leave unhooked, plug power cord back into powerboard, do backlights come on or do you get test patterns or anything?
            • hmendez86
              • Jun 2015
              • 344
              • united states
              #26
              Tv worked like a week before changin the main..but the tv ws doing a no normal working turn on on the first try and working fine once is turn off and wanted to turn back on it wont work just green and orange ligth...so now i change the main i got it to work, but now no backligth i can see the image with flash ligth.
              • Diah
                • Feb 2013
                • 6363
                did you tested the fuse F2001 on the back light inverter boards... tell what voltage you have on it
                • nomoresonys
                  • 12156
                  • U.S.
                  #28
                  • nomoresonys
                    • 12156
                    • U.S.
                    #29
                    And check the voltage between the legs of your main filter caps, be careful HIGH VOLTAGE.
                    • nomoresonys
                      • 12156
                      • U.S.
                      #30
                      Not sure I follow, so the new mainboard never worked? If so you may have bought a bad one, see if your getting the bl-on and ps-on signals.
                      • hmendez86
                        • Jun 2015
                        • 344
                        • united states
                        #31
                        Yes its working i tougth it wasnt working i find out when i did the update thats when i realize it was good....
                        • hmendez86
                          • Jun 2015
                          • 344
                          • united states
                          #32
                          On the fuse on the inverter is good both ways i get 41.5v..i dont know it thats to high or to low.
                          • hmendez86
                            • Jun 2015
                            • 344
                            • united states
                            #33
                            The tv off the big cap 167.5v....tv on 391.5v....
                            • Diah
                              • Feb 2013
                              • 6363
                              ok... try now ( wake up mainboards action to the backlight section ) :
                              with flash light control yours sony... open the menu setting and bring the backlight setting down to 1/3 ( if the high level 100 set it to 30 , if the high 50 set it to 20 ) then exit the menu plug the TV out from wall socket ( dont turn off with remote )....... leave it around 30 minutes off then plug it back to wall socket.
                              • nomoresonys
                                • 12156
                                • U.S.
                                #35
                                So you could not update the original mainboard, just like you did with the new one?
                                • nomoresonys
                                  • 12156
                                  • U.S.
                                  #36
                                  Is this with new mainboard or original??
                                  • hmendez86
                                    • Jun 2015
                                    • 344
                                    • united states
                                    #37
                                    This is the new main board
                                    • hmendez86
                                      • Jun 2015
                                      • 344
                                      • united states
                                      #38
                                      Could update the original it shuts off about 10 after being turn on and then gives me green orange ligth and stays like that..
                                      • nomoresonys
                                        • 12156
                                        • U.S.
                                        #39
                                        Ok, did you try Diah's suggestion in post #34? I think it was to see if tv stayed on longer. You can try this reset: With tv on, hold down the up button on remote, press power on tv button board, tv should turn off then back on, when it turns back on release the buttons, see if tv works any different, try it with the new board, then maybe the old one too.
                                        • nomoresonys
                                          • 12156
                                          • U.S.
                                          #40
                                          Might need to do some testing on the led driver board but orange and green is usually a software issue as in needing an update/pairing.
                                          • Chrissygizmo
                                            Sony KD-55XG9505 lines on screen problem
                                            by Chrissygizmo
                                            Hello again everyone,
                                            This is my latest mission, to try getting this Sony tv back to normal working order…
                                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                            02-19-2025, 11:31 AM
                                          • thelankanguy
                                            Sony KD-55X9000F TCON Issue
                                            by thelankanguy
                                            The TV shows a black screen with no image.
                                            TCON ribbon connectors were disconnected individually for image and there was no half image even.
                                            Later both ribbons were disconnected and TCON voltages were tested.
                                            12V, 3.3V, 1.8V were seen present but VONE signal reads 0V.
                                            There is also a short to ground in this circled inductor.
                                            Is this a TCON issue or something else ?...
                                            12-13-2024, 12:27 AM
                                          • crackedprint
                                            Sony HCD-HX80R Amplifier Volume Control Problem
                                            by crackedprint
                                            I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                            I have tried a Cold Reset as per the service manual.
                                            I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                            I have looked all the way through the service manual and tried many online...
                                            01-21-2025, 12:18 PM
                                          • retrorepair
                                            SONY KDL-40P3600 Picture Problem
                                            by retrorepair
                                            Hello gurus, hope you can assist me...
                                            I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                                            I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                                            Thanks in advance.
                                            10-11-2024, 05:12 PM
                                          • YasaCh
                                            sony kd-49xf9005 4 red blinking problem
                                            by YasaCh
                                            Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
                                            05-05-2025, 08:40 AM
