Re: Sony OLED XBR65A8G no video, PSU problem?
Thanks for the reply. The new board I ordered from Encompass (https://encompass.com/item/11914122/Sony/A-2229-191-A/) was identical to my old board. I guess its possible I got a bad board. I am going to take it to an actual Sony authorized repair place today and let them deal with it. I don't have the time to keep messing with this. THANK YOU VERY MUCH for help. I will post final results when I get it fixed.
yours replacment main board which you call it before ( brand new ) is defect or beelong to other serie which it could be the socket on it which connect to PCB had differnet wiring pin asigment rather than the original.
2- yours PCB as i wrote before OK.
3- yours Original main boards ( defect ) no start signal sending to PCB to turn on EVDD & VIN
dont do any things ells just bring working MB.Leave a comment:
i am much concerned now if you are doing the things correct.. because when you are telling me here it couldnt be.. as i am not native english speaker i used to write you with points No. if you followed it we will be close to the issue. nso dont make any jumber .. connect your replament main board to PCB and all other cable 2LVDS / 4Ribbon/EVDD/VIN all in place either the WIFI Module. and turn on
1- consider it may dont turn on imeditly because of the last state in case it was Standby.. so you need manual turn it on.. if it did any time you want toturn off just plug it out from wall socket to remain at the new last state to power on not to go to standby.
2- write here all your messurments on the sockets of PCB include vin and EVDD
Symptom:
TV randomly restarting with increased frequency overtime until eventually would not power on
Issue: TV will not power on. No LED. No Signal from Optical Audio Out
Troubleshooting:
Task 1: Removed back panel and tested voltages on PSB
Result 1: No voltage present on cable terminals going to main board or T-CONN
Task 2: Removed PSB cables going to main board and TCON board
Result 2: Only voltage present on board terminal to main board was the Standby PIN at 3.5 volts
Task 3: With main board and TCONN power cables removed from those boards, made pigtail to bridge/jump Standby, Power On, TCON ON, EVDD ON
Result 3: Note: When I plugged the pigtail in I could hear an audible click at on PSB board.
Voltages observed below:
*PSB Terminal to Main Board*
Row 2 Volts Row 1 Volts
BL_ERR 0 TCON_12_ON N/A
AC_OFF_DET 0.49 EVDD_ON N/A
STBY N/A Power ON N/A
GRND N/A GRND N/A
GRND N/A GRND N/A
GRND N/A GRND N/A
REG_12V 12.8 REG_12V 12.8
*PSB Terminal to EVDD and VIN*
TCON_GRND N/A TCON_GRND N/A
TCON_12V 12.8 TCON_12V 12.8
EVDD_GRND N/A EVDD_GRND N/A
NC EVDD_GRND N/A
EVDD 22 EVDD 22
EVDD 22 EVDD 22
EVDD 22 EVDD 22
EVDD 22 EVDD 22
Task 4: Unplugged the two LDVS cables going from TCONN board to Main Board and plugged in pigtail to energize the PSB
Result 4: TCON EVDD terminal was receiving 22 volts from PSB and VIN terminal was receiving 12 volts from PSB. Screen did not power on
Task 5: Ordered new main board and installed and reconnected all connectors. Installed Optical Audio Cable. Powered on and left for 30 mins. Also tried to power on with button and remote.
Result 5: No change. Voltage was null across the board on the PSB terminals to the main power board and TCONN board as it was in Task 1 Result. No signal at optical audio cable. No audible click at power supply.
Task 6: Reinstalled original Main Board and began unplugging components like the WIFI card and IR sensor and plugging in the main power cable to the wall.
Result 6: I was able to read 12 volts coming from the PSB to the MAIN board taking the reading at the main board but am unable to duplicate this result nor did this allow the screen to power on.
It seems like the PSB isn't receiving the signal to energize the Main / TCONN circuits. And even when the TCONN was energized with the bridge/pigtail screen didn't power on.
Any further guidance you could provide would be greatly appreciated.Leave a comment:
The most concerning to me is when following your initial steps to power on the screen via the bridge/jumpers did not work, but the PCB and TCON were getting the correct voltage.
Thank you again for your patience. I apologize my steps were not detailed and bulleted. I will provide better write up tomarrow.Leave a comment:
2- write here all your messurments on the sockets of PCB include vin and EVDDLeave a comment:
i asked you at my post above to put every things back as it should. and turn on... the sign of turning on the optic audio output port should lid red color.. if you have this mean now the main board working so check the vin and evdd if present on both side of the fuses at the t-con side. if okay too... try to remove load from main boards for exmple disconnect the WiFi module
So with the jumpers in place and the 2 LVDS cables unplugged I was able to get the correct voltage to the TCONN board from PSB. However, the screen still would not power on.
After I put everything back to normal configuration. I am back at the same problem.
-No power is being output from the PCB to EVDD. VIN is getting 12v. screen black.
-With PCB plugged back in, verified 12 volts going to main board from PSB. No response when pressing power on button.
-Removed WIFI module, no change. unplugged IR SENSOR no change
-No signal from optical audio to indicate main board power up.
Its like the main board is not calling to turn the power on?Leave a comment:
EVDD & VIN voltage correct and the set doesn't shutting down ? if yes..then
remove all jumpers and put back the 2 LVDS in place. then turn on , see if the set turning on ( by remark the optic audio output port ) .. and tell if it remain on and whether you have VIN and EVDD correctLeave a comment:
Diah, Thank you very much for responding! I did that and have now verified that I am getting correct voltage from PCB to TCON via EVDD (22 volts) and VIN (12 volts). However, I still have a black screen. The way it died doesn't make me think its the panel.. continually restarting until it would not longer power on (screen and picture were fine). Anything else you can think of that could help me narrow down this problem?Leave a comment:
So I got a brand new main board hooked it up same problem.. Went back to T-CON troubleshooting (unplugged all ribbons (2 to Main 4 others at bottom). So I noticed that when bridged and getting all power required at PCB and then plugging in the EVDD power remains and getting 22 volts at PCB and at TCON.. However, when I plug in the VIN connector from PSB, I hear a click at PSB and no voltage any where. Is this a bad TCON board?
1- you need to disconnect the main board from PCB
2- only disconnect the 2 LVDS between main boards and T-CON
3- all 4 ribbon should be in place between T-CON and panel module
4- make the bridge on PCB as you did before..Leave a comment:
yours PCB are fine... if yours sony when every things in place and there no T-CON 12 and EVDD mean the problem at main boards.. however start with
following my post#4 run the panel module as stand alone.Leave a comment:
Hello all, thanks for letting me join this forum. (please let me know if I need to start a new thread.
I am having the same issue with my A8G except my TV all of the sudden decided to turn off one day and kept power cycling. Did a reset to factory and got to the register you google account and die and will not turn on anymore. No led indicators before or after the failure.
I have done all the aforementioned steps but my PSB is only pushing 22 volts to the EVVD. I even removed the PSB from the chassis all other voltages are nominal and made the bridge to STANDBY, Power On, TCON_ON, EVVD ON. But like I said only getting 22 V from all EVVD outputs from the PSB. Would this cause my TV not to turn on? On a side note, when I put everything back together and plugged the PSB into the MAIN, the standby voltage disappeared.
Any further insight would be greatly appreciated. Just don't want to buy a PSB and it turn out not to be an issue.
----------------------------Break Break Voltages I recorded-----------------
PSB Removed from chassis
PSB To Main Board
Standby Voltage 3.5
TO VIN and EVDD
None
PSB Removed With Bridge to Standby, Power ON, TCON ON, EVDD ON
2 1
STBY 3.5 Power ON N/A
GRND GRND
GRND GRND
GRND GRND
TO VIN EVDD
TCON_GRND TCON_GRND
TCON_GRND TCON_GRND
TCON_GRND TCON_GRND
EVDD_GRND EVDD_GRND
EVDD_GRND EVDD_GRND
EVDD_GRND EVDD_GRND
EVDD_GRND EVDD_GRND
NC EVDD_grnd
EVDD 22 EVDD 22
EVDD 22 EVDD 22
EVDD 22 EVDD 22
EVDD 22 EVDD 22Leave a comment:
Hi, I bought a defective OLED Tv thinking I would just replace the defective board and make it work. The problem was that the TV would turn on with sound but no image. I replaced the TCON first, didn't do anything so I replaced the main board and psu boards too but to my surprise the problem is still there.Leave a comment:
So what was the outcome of this TV?
I have the same TV as the OP and didn't know if I should start a new thread or not.
Pretty much the same issue, except instead of a red line down the screen, I get a blank screen. 4 red blinks when powered on. Sometimes I could get it to power on after a hard reset, but just blank screen with sound.
I ran the power board stand alone and got these voltages:
EVDD = 22.05V
TCON_12V = 12.69
REG_12V = 12.75
When I plugged in the TCON and tried to power up without main board attached, I didn't get any picture on the screen. I also tried replacing the TCON board but I still did not get any picture on the screen when doing this test.
Does this mean I have a bad panel? Is EVDD correct at 22.06V or should it be closer to 24V?Leave a comment:
Ah! Sorry, I thought I mentionned it: when I turn on the tv there is the thin red line for a second (while EVDD is present) and then it dissapears when EVDD goes away and the screen is all black and I can hear the sound. I felt it was a psu problem too.
I'll take everything apart and let you know if i see anything.
**any way to show me what you mean by edge boards?
edge board the panel PCB board where the 4 ribbon connectedLeave a comment:
**any way to show me what you mean by edge boards?Leave a comment:
if you can access to the edge boards am sure you will discover visual issue. let see.Leave a comment:
by SpikemanHi, I'll tell you the story of this PC.
The PC was repaired because it had a shorted power supply. What happened was that the plastic covering the buffer battery positioned by the manufacturer on the capacitor melted, thus generating a short.
After the repair, the PC worked, I installed Windows 11 and I may have had some problems with the video drivers, but after a bit of tinkering I think I solved them.
However, the PC later presented the problem in the video shared very frequently.
The problem also occurs at startup, in the bios and when using it as a monitor thanks...-
02-27-2024, 10:17 AM -
by Gibon378PC Specs:
- CPU: Ryzen 5 1600
- GPU: GTX 1080 Palit JetStream
- MOBO: ASRock ab350 PRO4
- RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
- PSU: XFX 650W (don't remember what model)
- OS SSD: ADATA SP920
- OS: Windows 10 21H2
Problem description:
Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders... -
by zimeyhHi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
by ChrissygizmoHello again everyone,
This is my latest mission, to try getting this Sony tv back to normal working order…
I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried... -
by hugocarmoHi everyone.
I have the following problem.
I have a Grundig GV-250 VCR which has not been used for over 10 years. When I turned it on, the fuse of the PSU burned out, after being replaced it burned again, I ended up verifying that I had the bridge rectifier and the mosfet in short, I ended up replacing it, and I replaced all the electrolytics of the PSU. However, it started to behave strangely, as I will show you in the video that I will attach as a link.
In short, I ended up replacing all the ICs on the power supply CNY17G, TDA4605, TL431, TDA8137, TL082CP, AN3824K, L2720,... - Loading...
