TCL 55S401 - No Backlight (powers on, sound, flashlight image)
  • Chris24
    • Feb 2014
    • 42
    Hey everyone - I have a TCL 55S401 with these symptoms: powers on, has sound, and a black screen.
    I tested with a flashlight and can see the TCL logo and setup screen. I did a factory reset and with a flashlight I can now see "select language."
    Following instructions from Budm in a recent post for a TCL 55S405 without backlight, I did the following tests:
    Power Supply to LED (pin label is under board)
    Tested w/ multimeter at 200V and tv unplugged to plugged in to power on:
    P10 LED1+ : 0
    P9 LED2+ : 0>48~60>0.69
    P8 NC
    P7 LED2- : 0 > 0.01
    P6 LED1- : 0 > 0.01
    P5 LED4+: 0 > 0.01
    P4 LED3+: 0 > 0.01
    P3 NC
    P2 LED3-: 0>22~25>0
    P1 LED4-: 0
    I also tested the PS to MB and will post later, but pretty much had 12V everywhere labeled 12V and 3.3V on P_Dim and 3.5V BL_ON
    Another random symptom is that the TV turns on immediately after plugging into the socket instead of going straight to standby and waiting for me to push the power button. Not sure if that matters
    Pics to follow:
  • Chris24
    • Feb 2014
    • 42
    Re: TCL 55S401 - No Backlight (powers on, sound, flashlight image)
    Images attached. Any help figuring out if its the LEDs or something else is MUCH appreciated
    • neilc6
      • Nov 2015
      • 1550
      Those TCL have lots of backlight failures. Most TVs will remember what state they were in if unplugged so if it was on, it will turn on automatically. If you want to repair TVs, time to buy a LED tester.
      • Chris24
        • Feb 2014
        • 42
        Thanks Neil, I’ve heard that is common. Figured I would rule out the PS at least first and since I didn’t get a jump in voltage was wondering what the deal was. What do you think about testing on the PS?
        I’ve heard these TV LEDs are a little easier to swap so if that’s the case I’d give a go
        Great point about on/off
        • neilc6
          • Nov 2015
          • 1550
          https://youtu.be/I32MBlbRWMs
          https://youtu.be/2uJzGlAaM0M
          Replace all your strips with new and turn down the backlight level.
          • handsworth
            • Oct 2015
            • 174
            Just be careful removing the screen. Those babies are glued down.
              Based on your reading in post #1, it looks like you have open circuit in LED #2. this TV has LED 2 string connected in series with LED 3 string.
              If you leave the LED connector out and then keep the black probe on the chassis, red probe on LED2 + pin of the power supply board then turn on the TV while watching the meter to see how high the Voltage jumps up to.
              • Chris24
                • Feb 2014
                • 42
                With LED connector unplugged from PS I get:
                P9 LED2+ : 0> 68~101v > 0
                and
                P2 LED3- : 0 > 78~90V > 0
                The PS clicks once and I get a 90v or so reading and back to 0 and then a few seconds later it clicks again and I get a 65V or so reading then back to 0
                  It goes into protection shutdown since no load (LED strings) are not connected.
                  So do you have LED tester to test the LED strings?
                  • Chris24
                    • Feb 2014
                    • 42
                    Opened her up and tested the LEDs. Had two LEDs out, one top strip and one on bottom strip on left side of screen. Got a replacement set of light strips (not skilled enough to replace a single LED) and went ahead and replaced them all, and now the TV works, nice and bright. Will turn the backlight down.
                    Thanks to bud, Neil, and hand for your responses. Always learn something new on here
                      Thanks for the follow-up on the repair.
                      • neilc6
                        • Nov 2015
                        • 1550
                        I got a TCL 55S405 with no backlights and cracked the screen removing the panel. I scanned this shopjimmy video to see if the panel was taped to the screen which it was. https://youtu.be/KaKi5aC9fUQ I then followed their procedure of running a plastic sheet along the edge to separate the tape. No problems with the bottom and side edges but the top edge uses stickier tape which is how I ended up damaging the panel. Better to use this procedure from bigdog8882 https://youtu.be/QdxSHeQFuwY
                        Sometimes with taped panels, I leave the frame attached and just separate it from the chassis but just assumed Shopjimmys method would work. On this model, the frame on the top sits inside of the chassis so a bit harder to unclip. I should have read all the comments from that video.
                        • DXseekerMO
                          • Feb 2018
                          • 1119
                          • US
                          I just installed backlights in this model 3 days ago. I used a hair dryer on the top edge of the screen and an old driver license slid between the screen and screen rest to separate them. Seems to work like a charm for me!
                          They call me......."threadkiller"
                          • david37g
                            • Mar 2012
                            • 18
                            I have a TCL 55S405 with no picture, only sound. The white light on the bottom came on when I pressed the remote power button. I wanted to check the backlight power supply. I tried the suggestion of Bud M to test led voltages with the led cable unplugged. When I put the power on the PS fuse blew. Does this mean the PS is bad?
                            • david37g
                              • Mar 2012
                              • 18
                              Found 2 bad mosfets on back of power board aod9n50 and two bad led back lights. Replaced the mosfets and all the led strips and the tv works.
                              • nwcs
                                • Dec 2015
                                • 311
                                • usa
                                Can you tell me how you got the panel off without breaking it. The top is glued down and I do not want to damage it getting it off.
                                • handsworth
                                  • Oct 2015
                                  • 174
                                  I use a feeler gauge. I believe it was at .25mm. Strong enough to break the seal but flexible enough go over the bezel humps. GO SLOW!
                                  • ChaosLegionnaire
                                    by ChaosLegionnaire
                                    09-13-2022, 09:02 AM
                                  • domix
                                    Sony KD - 65XF9005 - No image, sound OK
                                    by domix
                                    at tv KD - 65XF9005 i have a problem.
                                    Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                    is this a common problem for this tv?
                                    i attached pictures of inside. Supply board looks okey, no blowed caps....
                                    07-21-2025, 06:37 AM
                                  • Kartowl
                                    philips 47pfl6158k/12 image faded away, sound still coming from TV
                                    by Kartowl
                                    Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                                    04-23-2024, 12:57 AM
                                  • wolf1976
                                    samsung ue40d6100 has no backlight no sound and image
                                    by wolf1976
                                    hi to all
                                    on the above model of samsung i have the faults i have told already on the title
                                    iI have standby i can from remote control open and close the tv and it seems reacts the tv when i press someone button from remote control but and with the help of a torch i cannot see anything image on the tv and no sound
                                    any idea from someone what can i measure so i can find the problem ?
                                    the power supply is the bn44-00482a i cannot find the service manual so i can test if the leds are ok and maby these are the cause of my problem
                                    11-17-2024, 01:02 PM
                                  • howardc64
                                    LG 43UK6500AUA no LCD image, backlight and sound okay
                                    by howardc64
                                    Similar to another LG UK series here
                                    https://www.badcaps.net/forum/showthread.php?t=93943
                                    Have backlight and sound. no LCD image.
                                    • main board has integrated T-Con
                                    • main board T-Con has LCD DCDC/PMIC RT6950GQW QFN68 package. Richtek chip. Can't find datasheet. Chip generates VADD (10.44V), VGH (~28V), VGL (~-14.5V)
                                    • RT6950 pin 18-19 (clockwise) appeared to be bridged. Unlikely from my probing, looks like ball squeezage so it probably got hot
                                    • Cleaned up bridging. Pin 17 is VGL (-14V) Pin 20 is VGH (28V). Pin 18 (I think 19 too) jumps between VGL and VGH voltage
                                    03-12-2023, 01:04 PM
