Hitachi CPRX80 lcd projector
  • Christmasman30
    • Dec 2020
    • United kingdom
    hi there i have the above projector worked fine christmas eve for a few hours lamp only used 100 hrs or so and when shut down about 10pm shut down fine, went to swtich and boot back up christmas day and it had the red power light briefly illuminate and nothing else fired up tried a couple times in case of over heating but nothing will boot or light at all where should i start looking at hasnt been dropped or abused and was setup and left there for a couple days prior to main use. many thanks
    colin
  • Christmasman30
    • Dec 2020
    • United kingdom
    Re: Hitachi CPRX80 lcd projector
    I don't suppose anyone could. Give. Abit of help to fix this projector please
    • Diah
      • Feb 2013
      • 6435
      if the info you listed were not enough.. how other will answer and share thier know how..
      you mentioned only on the power LED indicator light on steady RED. how about other LAMP and TEMP ? did FANs running or all silent ???
      only Power steady RED mean no boot / STB condition. disconnect all cable input from Projector. take it out from wall socket for at least 10 minute then try to turn on,
        • 21585
        heres the service manual, the test points are on page 10, and troubleshooting steps on 11 .Go through each step and post your results .
        • Christmasman30
          • Dec 2020
          • United kingdom
          hi there the light briefly lit on power but then went out and temp and lamp lights didnt illuminate at all, the projector was plugged in on mains wtih no other cables attached so cabling and external sources are not the problem as there isnt any other sources aconnected, im just a bit stumped tbh why one night it would operate as normal then the next night even after unplugging all the cables it didnt even want to power up in power cycle mode.
          • Diah
            • Feb 2013
            • 6435
            did you use the clip key between PC input to turn it off???
            you can try my trick to cause error on it, for example open the lamp door or move the lamp from it place and close the door in place.. after that turn on it will register error.. plug it off.. put the lamp in place or close the door ( remove the error you did ) then leave it for 10 minute and plug it on.. it will reset the error and hopefully it will turn on
            • privato89
              Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
              by privato89
              I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
              Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
              Let's begin:
              Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
              03-26-2024, 06:37 AM
            • Luke Anders
              Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
              by Luke Anders
              A few details about the laptop itself:
              Name: Lenovo Legion 5
              Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
              BIOS Version: GKCN60WW
              EC Version: GKEC65WW
              Serial Number: PF39AQ7Z
              Board Model: NM-D562 Rev 3.0
              RAM: 16GB Installed, DDR4 (brand new)
              NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
              I bought this laptop recently from eBay as a faulty device....
              10-12-2024, 05:13 AM
            • hinisa
              Xiaomi router freezes at boot after re-capping
              by hinisa
              I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
              When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
              After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
              Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
              07-08-2023, 05:58 AM
            • NolesFan
              Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
              by NolesFan
              Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
              10-24-2024, 06:36 PM
              Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
              09-06-2024, 06:11 AM
