low leakage or low impedance caps?
  • as1jc
    • Nov 2020
    • 16
    • philippines
    ive been given a panasonic tc32lx60 which to get working only needed the main power supply filter cap changed and two fuses. its a 2006 model with probably beaucoup hours on it, want to recap the whole set as its got only about 30 e caps in it. i went ahead and wrote up a cap values list but i wasnt sure about the types of ecaps that were used. in my audio experience a low impedance cap is used in filter or bypass applications. a low leakage is used in the signal path , theres a variety of types in the set and the nichicons i can figure out but theres some rubycons that were green that im not familiar with. i also have NO video repair experience, does some kind soul have a quick and dirty answer? and does anyone know anything about converting these older sets with cfl's to led's?
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: low leakage or low impedance caps?
    ESR Very Low Equivalent Series Resistance (ESR)
    Ideal for Power Supplies- High ripple and current capability
    • as1jc
      • Nov 2020
      • 16
      • philippines
      would nichicon uhe and upw fill the bill?
      • chrismurphy
        • May 2014
        • 251
        • australia
        yes or any ESR
        • as1jc
          • Nov 2020
          • 16
          • philippines
          well thank you kindly any of you fellas doing led conversions? im not planning on it as this thing still works at present but will if backlights fail. no cfls here that i can find.the factory service manual is ratcrap as well with no board schematics and they even left out the cfl driver board!! and its a hobby anyway.what impressed me about this set is the build quality in the era bpc (black plastic excrement) and i think its worth keeping around.
            by momaka
            03-15-2023, 10:17 PM
          • SwedishDiesel
            Dell Optiplex GX260 - Advice Needed for Polymodding Motherboard
            by SwedishDiesel
            Howdy folks,
            I have an Optiplex GX260 that blew a couple of those troublesome Nichicon HM series (ultra low ESR) electrolytic capacitors. Because said caps are obsolete, they are pretty much impossible to find on the market; I did find a listing for some but I believe they are counterfeit. I feel the easiest thing to do would be to replace all the blown caps with polymer ones. I am by no means an expert in electronics, and I've found a fair bit of conflicting information, so any guidance or confirmation would be greatly appreciated. While from a practical standpoint it's not worth...
            10-30-2021, 12:47 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
            by momaka
            03-12-2025, 03:42 PM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
