Philips 50PUS6162/05 Vertical Lines - Likely the T-Con...
  • Jimmy Jangle
    • Jun 2013
    • 30
    Hi all, back again after a few years!
    My Philips 50PUS6162/05 last night developed a fault out of the blue where sound was still playing, but the display was just displaying vertical stripes/lines of varying colours.
    Being no stranger to this sort of issue, I'm assuming that it's something as minor as a loose ribbon connection to the T-Con, or a replacement/repair.
    I believe, based on preliminary checks online, that the T-Con in question is a 55T32-C0F.
    What I would like to know is, say I do need to replace, and see one online with the same model code as above, but is listed for a different brand (Toshiba, Vizio, Hisense, etc), will it still work with my TV, or does it need to be specific? Apologies if the question's a bit dense - it's been a few years since I've needed to carry out a fix of this nature so am a little rusty.
    Regards,
    Matt
  • Jimmy Jangle
    • Jun 2013
    • 30
    Re: Philips 50PUS6162/05 Vertical Lines - Likely the T-Con...
    Regards,
    Matt
    To clarify further, I see countless models online of 55T32-C0F, but the white sticker attached appears to have different information (starts with UZ-5550T32C10).
    Do the details on the white stickers need to match exactly, or is the model number enough?
    • as1jc
      • Nov 2020
      • 16
      • philippines
      ive been wondering the same myself on a different tcon in a different set. what i dont know is if the tcon boards are PROGRAMMED differently that MIGHT be the difference. in my case a google search came up empty. soooo i rolled the dice and opened my wallet. now i get to wait a month to find out. given my lack of success guessing on 50-50 odds possibilities in evil soduko puzzles i am not hopeful
      • Jimmy Jangle
        • Jun 2013
        • 30
        This is the problem I'm facing at the moment.
        From what I've seen, it looks like the model number (first batch of numbers on the white sticker) is important.
        When I checked 5550T32C10 on shopjimmy, it did advise that model 5550T32C11 is one that potentially works also.
        • as1jc
          • Nov 2020
          • 16
          • philippines
          it would seem that the manufacturers go to great lengths to achieve low to zero interchangeability in seemingly, totally interchangeable, in appearance, boards
          • as1jc
            • Nov 2020
            • 16
            • philippines
            it drives a man nuts i swear! to know the meaning and purpose of all the numbers would be useful,but those that know arent talking.
            • Diah
              • Feb 2013
              • 6365
              could you show us photo on the issue you described after you feed signal and can hear sound on the set ??
              • Jimmy Jangle
                • Jun 2013
                • 30
                Can't post photo now as have taken T-Con out in anticipation of replacing it, and also at work.
                Could hear sound perfectly fine, and when pressing buttons on remote to bring up menu, Netflix, etc, the colour of the lines would change and fade in/out accordingly.
                • Diah
                  • Feb 2013
                  • 6365
                  you are fast judgment on the t-con.. while main boards BGA issue on main ic produce same issue you just wrote.
                  EDIT:
                  BTW there are ribbon disconnection test to be sure you got blank half white screen.. to terminated that issue not located at panel.
                  • Jimmy Jangle
                    • Jun 2013
                    • 30
                    Not my first rodeo; I was probably too quick jumping to that conclusion, but given T-Cons are cheaper than main boards, and it being the week before Christmas, I'd rather eliminate that as a cause before looking at the main board.
                    However, I wasn't aware of that, thanks for pointing that out.
                    [EDIT] I'll try the ribbon test when I've some free time this week, thanks again.
                    Still would like to know how interchangeable T-Con boards are however, should it come to that.
                    • Jimmy Jangle
                      • Jun 2013
                      • 30
                      I've put the T-con back in and tested with one ribbon disconnected at a time; each time shows one half a white screen, the other black.
                      If I plug them both back in I either get black screen or white stripe about 10cm wide going down the centre of the screen.
                      Any suggestions would be welcome!
                      • Diah
                        • Feb 2013
                        • 6365
                        did ribbon test was with signal and you can hear sound as i asked before ...???
                        with out photos of test result or your T-CON boards & Main boards to see what kind of boards we are dealing with.... if the t-con boards owned SPI Flash..
                        • Jimmy Jangle
                          • Jun 2013
                          • 30
                          Hi, had xbox one plugged in, could hear sounds as navigated around.
                          • Jimmy Jangle
                            • Jun 2013
                            • 30
                            Bump
                            • Stanley1843
                              Screen Display Vertical Multicolor Lines
                              by Stanley1843
                              Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                              06-29-2024, 11:54 AM
                            • Daren87
                              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                              by Daren87
                              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                              08-13-2023, 03:25 PM
                            • gpo23
                              Sony KDL-40V3000 - Vertical lines
                              by gpo23
                              i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                              With the new t-con the color are good but there are vertical lines on all the screen :
                              I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                              Is there a way to fix the vertical lines on the new t-con ?
                              Thank you for your help
                              gpo23...
                              10-04-2023, 09:11 AM
                            • x_orange90_x
                              TCL 50S535 bad tcon or panel issue?
                              by x_orange90_x
                              Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                              03-29-2025, 11:02 PM
                            • rfxcasey
                              Vertical Lines on Half of LCD Display
                              by rfxcasey
                              I have an Siemens HMI with vertical lines on half of the screen. These lines aren't scrambled garbage but rather very regular in pattern and color. I have replaced the LCD with a new one and still the problem persists. I'm wondering if this isn't indicative of a bad video process chip or video memory? Any help would be appreciated. The cable appears to be OK but one pin on the header is unpopulated, though there isn't any loose wire to suggest one broke off or popped out of the connector. In the picture below where the connector is busted out of the side, I did that with my small screw driver...
                              05-16-2024, 06:52 AM
