Vizio E470VL - Lines & garbled image....sometimes
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    I've got a stumper, I can't pinpoint whether it's a tcon, tab bond, or signal process issue. Temps cold/hot don't seem to affect it....sometimes it's just perfect as can be, most the time it looks like this:
    This is an overscan crosshatch, where it appears ok....but it's still doing it.
    I've cleaned the ribbon contacts till I'm blue in the face, no change. Poking/twisting/applying pressure to the signal processor/TCON board doesn't change anything...neither does it change anything with the tab bond PCB's. There's no rhyme or reason to the malfunction at all....as a matter of fact, as I typed this, it straightened itself right out and is pretty as a picture (pun intended).
    PSU is putting out correct & stable voltages....I'm kinda baffled by this one....perhaps some of you more experienced TV guys might have some feedback. This belong to a customer, dropped off with the usual instructions of "I don't want to spend a whole lot" ...and I'm not a tech to feed parts until the issue goes away...but not being able to narrow this one down isn't helping. This is the first one I've not been able to isolate to either the panel (bad tab bonds) or the signal processor/TCON board (integrated onto one board with this model). If it's the panel, obviously the set is a goner.....I searched the panel number (LG LC470WUH), and no red flags came up of them being problematic....but I'd certainly like something more positive before I pronounce it.
    The boards:
    Any input would be super.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • Diah
    • Feb 2013
    • 6379
    Re: Vizio E470VL - Lines & garbled image....sometimes
    the panel LC470WUH 120Hz 3D one. for testing need to use 1080P photo mage only (not pattern image)
    if the displaying show perfect picture after while , its of sure currents issue at PSU. Volts are corrects but with no juice (currents)
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      "Photo mage" Something lost in translation? What is that?
      Maybe you're onto something, some patterns would display fine, while others would garble when running the burn-in loop. Voltages were correct with the set powered on, but not fed any signal....but when displaying some patterns (all are in 1080P), I could hear a faint whistle/buzz/hiss from the area where the ribbons interface with the tab bond panels.
      That said, some of the 'troublesome' patterns would also display perfectly at times. The PSU is made by Delta.
      Team : 49813
      Join in!!
      Team Stats
      • Diah
        • Feb 2013
        • 6379
        Maybe you're onto something, some patterns would display fine, while others would garble when running the burn-in loop. Voltages were correct with the set powered on, but not fed any signal....but when displaying some patterns, I could hear a faint whistle/buzz/hiss from the PSU area.
        photo image. at TV platform could be simple jpg or video img/mp4
        resolution supported by the panel the highest 1080P, so we need to use only highest resolution which are the best will be ( Photos )to displaying.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          I edited my above post before you responded....but the patterns are in 1080. Sencore VP403 supports these resolutions. I did connect a PC. I'll recheck the PSU out voltages. The whistle/buzz/hiss is coming from the top of the panel somewhere, not the PSU...as per the edit. It changes with various images.....kind of a benign symptom, I hear this in lots of sets.
          Team : 49813
          Join in!!
          Team Stats
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            As before, being driven in max resolution.....
            Desktop
            I measured the voltages with each varying image, there was no fluctuation.
            1) 5.3v
            2) 5.3v
            3) 5.3v
            4) GND
            5) GND
            6) GND
            7) GND
            8) 12.3v
            9) 12.3v
            10) 12.3v
            11) 2.4v
            12) 3.4v
            13) 0.2v
            14) 2.4v
            Just a FWIW.....note how garbled the window is, but the text behind it is perfectly legible.....just a bizarre observation.
            Team : 49813
            Join in!!
            Team Stats
              Pictures of the T-CON board?
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16956
                Here's the high resolutions of the ones above.
                The tcon and signal processor are all one board on this model. If you need closer up I can get you some tomorrow.
                Team : 49813
                Join in!!
                Team Stats
                • Diah
                  • Feb 2013
                  • 6379
                  in such issue of distributed displaying we need to Testing the set with out any out source video processing circuit, such you are now using HDMI Input. USB INPUT or TEST CH48 Tuner signal ...are direct methods for test, as both using the SET video processing circuit.
                  so in case you dont have RF Channel test equipment's ..Copy different resolution test JPEG Photos on USB drive and play them direct on the set.
                  • Topcat
                    The Boss Stooge
                    • Oct 2003
                    • 16956
                    I already did that. Same garble on all inputs (RF & composite). Startup splash is also garbled, as is the OSD functions. Issue is after signal processor. TCON or panel/tab bonds as I initially thought....just need to pinpoint which.
                    Team : 49813
                    Join in!!
                    Team Stats
                    • Diah
                      • Feb 2013
                      • 6379
                      LVDS could be issue too.. so they need deep inspection at both ends with very good magnifier
                      • Diah
                        • Feb 2013
                        • 6379
                        one things more could be issue too. the MFC section at firmware.. from service menu if you do hard reset will be enough.
                        so for me i dont think its hardware (parts) defect. just the points i mentioned or we have leak bad soldering some where..
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16956
                          I've tried every trick I know of to access the service menu....not working. https://factory-reset.com/wiki/Vizio_Service_Menu
                          FWIW, when it was cold, it displayed perfect for about ~5 minutes....then garble.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • Diah
                            • Feb 2013
                            • 6379
                            so you are close to narrow the issue, use freeze air spray . starting from secondary circuit at PSU and the T-CON section at main board/nand / eeprom etc.
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16956
                              What's the secret for the service menu though...that one is bugging me. I've never had one I couldn't get into.
                              Team : 49813
                              Join in!!
                              Team Stats
                              • Diah
                                • Feb 2013
                                • 6379
                                search after main boards No. not model. Vizio some models belong to other brands..
                                about cold or warm state it garble. when it start garble plug it from wall socket and plug it on again. if it show clear display then its MFC FW. if it garble then its related to cold & warm of parts
                                • Diah
                                  • Feb 2013
                                  • 6379
                                  i found on net .. service menu from the panel at the tv side press menu and immediately followed with power
                                  • Topcat
                                    The Boss Stooge
                                    • Oct 2003
                                    • 16956
                                    Maybe its getting narrowed here. Cold air anywhere on the PSU renders no changes. Same with the tab bonds, nothing changes. If I blast the tcon/signal processor board, things happen. The 'garble' changes patterns but never straightens out. Looks like perhaps some reflowing is in order.....but atleast it eliminated the PSU and the tab bonds.
                                    Team : 49813
                                    Join in!!
                                    Team Stats
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16956
                                      The focus of attention is now this chip/area.
                                      If I hit that chip with the air, the display goes nuts and actually freezes up until the chip warms back up. Never do I get a 'normal' image on the display.
                                      Hitting the CPU (inside the can) has no affect. Neither do any of the tuners/IO areas. It's down to something in that TCON chip area (tcon was my original suspect, but couldn't confirm).
                                      I've reflowed this area several times, it has no corrected the issue.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                        There are some SMD Lytics cap in that T-CON section on the main board, may be you can try pin point cold spray on those caps.
                                        • brad2157
                                          Vizio E70-E3 Two white vertical lines
                                          by brad2157
                                          I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                                          Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                                          Replacement main board - Boots up fine, but starting...
                                          12-13-2021, 05:11 PM
                                        • x_orange90_x
                                          Vizio V585-J01 dancing lines and image doubling
                                          by x_orange90_x
                                          I got this tv yesterday and it shows a screen full of colored vertical bars and horizontal lines that move, change, and dance around. When the set is powered on there is a slight buzz from the tcon. I removed one ribbon at a time and this was the result:
                                          Right side connected, left side disconnected = half image on right (somewhat distorted, see photo attached) white screen on left. NO buzzing from TCON
                                          Left side connected, right side disconnected = right side black, left side white with distorted horizontal lines near top of screen. Buzzing from TCON
                                          I swapped...
                                          06-12-2024, 07:57 AM
                                        • viking509
                                          vizio e65 e3 LED tv color vertical lines center tv only
                                          by viking509
                                          I recently replaced the led backlights with LB65041 LED Backlight Strips and after putting it back together the backlights work but there are only colored vertical lines only in the center of the tv. I can see the Netflix logo (jumbled) after a minute or less the screen went dark. When I turned it on again the lines were back. Then I replaced the t-con board but the same vertical lines in the picture. My question is what is my next step? Could it be a source tab bond issue? A buffer board issue? Could I have loosened a connection to the panel when replacing the backlights? Should I replace the...
                                          03-21-2023, 12:48 AM
                                        • Bugman1400
                                          Vizio E470VL got +5VSB, but no 12V
                                          by Bugman1400
                                          EDITED: I thought my Vizio E470VL has +5VSB and no 12v on the PS board, but after plugging the cable back in and testing the pins on the Main board I realized that I do have 12V. I assume the 12V is turned on when the ON/OFF switch is pressed. The Vizio light in front does go from Standby Orange to White when ON. But, I still have no picture or sound. Test values of PS board are below.
                                          +5VSB= +5.09
                                          12V= +12.18
                                          PS_ON= +2.25
                                          I_ON/OFF= +3.27
                                          LAMP= +3.18
                                          DIM= +2.97
                                          Any more testing I can do on Main board or is it just a replacement?...
                                          09-04-2022, 09:19 AM
