Hisense 55P6 - No power no standby
+ More Options
Posts
  • samsonn
    • Jun 2020
    • 14
    I've got a Hisense 55P6 which won't turn on and has no standby light.
    I've cracked it open and measured the voltages on the connector between the PSU and main board, but got 0V on all pins. I have 330V on both of the big capacitors so we're getting power.
    Not sure where to check next. Grateful for any help.
    PSU details: Hisense RSAG7.820.7748 HLL-4360WQ. (I found a replacement but it's a bit pricey http://www.mxmee.com.au/index.php?ro...oduct_id=11815)
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Hisense 55P6 - No power no standby
    resolder all connections on the two transformers with the yellow tape
    • samsonn
      • Jun 2020
      • 14
      Thanks Chris I gave that a go but no luck.
      • R_J
        • 9535
        Check that D816~D819 are not shorted, If they are ok, it is likely a problem in the primary circuit around N803, when checking voltages on this ic you must use hot ground (IE:C811 negative lead). Check pin8 (or W823) It should be close to main cap voltage, then check pin3, this is the VCC, post the voltage reading
        Be careful checking voltages in the primary side, you are dealing with Mains voltage
        • chrismurphy
          • May 2014
          • 251
          • australia
          check fast recovery diodes vd816 to vd818 for shorts
          these boards usually have these fail
          • chrismurphy
            • May 2014
            • 251
            • australia
            sorry for the repeat post R_J posted the same
            • samsonn
              • Jun 2020
              • 14
              All the diodes seem fine. The voltages around the IC are:
              Pin 3: 20v
              Pin 8: 180v
              • samsonn
                • Jun 2020
                • 14
                From reading some other posts a Vcc of 20v seems reasonable? Not sure where would be best to check next, probably to verify that the IC is still good but not sure how to do that.
                • R_J
                  • 9535
                  VCC of 20v is normal, so the ic should at least be in burst mode, which would give some voltage on the secondary, It could be that the ic is bad and not driving the mosfets.
                  • samsonn
                    • Jun 2020
                    • 14
                    So if I were to measure the voltage on the gate of v805 and v806 that would give some indication on wether the ic is working?
                    • samsonn
                      • Jun 2020
                      • 14
                      Looks like the source and drain of v805 are shorted so guess I'll replace that and see if it works.
                      • R_J
                        • 9535
                        Check the resistors and diode in the gate drive of that mosfet, hopefully they are ok and it is only a bad fet.
                        • samsonn
                          • Jun 2020
                          • 14
                          So I've been thinking about the replacement mosfet I ordered. The dead mosfet had "CS840F A9h" written on it, which I could find the datasheet for but nobody was selling them. I ended up ordering this: https://au.rs-online.com/web/p/mosfe...escriptionLink as it seemed to be a pretty close match at the time.
                          I've since found that an IRFS840 would be an exact(?) match for the broken FET, and there are a few for sale on ebay (bit expensive tho). Wondering if its worth ordering the better match or if I should stick with plan A and uses the FETs I've already ordered?
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                          • LemoneyF
                            Hisense 50r6- no standby, no power, bad main board?
                            by LemoneyF
                            Hi all
                            I have a Hisense 50r6 that quit suddenly, immediately after turning it on. It no longer shows red a standby light and will not turn on. Completely dead.
                            I have tested the power supply and found the following:
                            363V and 373V across the input caps
                            bri- 0V
                            ana- 0V
                            vamp-17.03V
                            vamp-17.03V
                            stb- 0V
                            12V- 9.3V
                            12V- 9.3V
                            To the extent of my knowledge (...not far!) these numbers are normal for a Hisense power supply in a standby state, though I would like some confirmation that 9v...
                            10-12-2022, 07:44 AM
                          • EUWest
                            Hisense rsag7.820.5687 no power no standby light
                            by EUWest
                            Hi!
                            I have a power supply and on the TV no standby and no power. Have already installed a replacement power supply but the same problem.
                            When I test both power supplies the main capacitors while plugged in, I get 0v.
                            What could be the reason for this?...
                            04-14-2023, 08:59 AM
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                          • SkishyIshy
                            Sony Bravia XBR-65x900f: No Power, No Standby-light - however 3.3v STBY is present
                            by SkishyIshy
                            Hey All,
                            I have a Sony 65x900f that I purchased cheap because of a no-power issue.
                            I assumed that because there is no standby light visible, it would be an easy fix - however upon opening up of the unit I can confirm that the 3v3 standby voltage is making it's way from the power supply to the main board. I'm a little confused as to why there is no standby light.
                            I am firstly wondering if anyone has this model of TV, or has worked on one and can give me some insight. I have tried to find a service manual for this model, to no avail - and would really appreciate...
                            03-17-2021, 11:44 AM
