Insignia Part
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    Insignia Part
    Looking for an ES7923-1/MP02008 power supply.
    Insignia NS-LDVD32Q-10A is model number of set.
    LJ
  • nomoresonys
    • 12206
    • U.S.
    Re: Insignia Part
    There's a couple in that mess, looks like 25-30 bucks or so:
    https://www.ebay.com/sch/i.html?_fro...Q-10A&_sacat=0
    • edugimeno
      Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
      by edugimeno
      Hi There!
      I'm trying to help my friend who owns a restaurant be just bought.
      He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
      It's stuck using, I guess, the 2 sided tape that comes with the strip
      The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
      09-05-2024, 09:34 AM
    • G-Sting
      iPad Pro A1876 SHORT Part Identify Help Needed
      by G-Sting
      So My iPad was not charging and booting up . i went to a local technician and he checked with thermal and this Part marked in 1st Photo is Short.
      So then i went on to boardview and downloaded the schematics and identified this part in 2nd Photo. Now i am confused what exactly is the part called ? where should i get this from ?
      i contacted my technician and he sent me his BoardVIew screenshot in 3rd Photo. In his Boardview the part is called X2826.... Something
      SO My main concern is what part should i order what should i search the name for ?
      on Ipad...
      05-15-2025, 09:30 AM
      Apple MacBook Pro 13'' Early 2014 820-2530 820-2530-A 820-2530-B Boardview
      Apple MacBook Pro 13'' Early 2014 820-2530 820-2530-A 820-2530-B Boardview...
      10-22-2024, 03:26 AM
    • Yanleb
      Panasonic part number in service manuals
      by Yanleb
      In the Panasonic service manuals, both in the board schematics and in the part listing, the part numbers that are given are Panasonic part numbers instead of the actual part numbers.
      This is especially annoying for small SMD components like diodes and transistors when you only have 1-3 digits printed on the component body.
      For an example, look at the attached PDF.
      Do you have a way to cross reference the Panasonic part number with the actual part number?
      Thanks....
      07-03-2023, 08:16 PM
    • FreakyMex
      Trouble to identify part (Lunii screen) for replacement
      by FreakyMex
      Hello guys. I'm a complete noob in electronics. I'd like to repair my child Lunii's (a "story box"), basically an audio player that allows the childs to choose between several options the places, characters, objects of the story, and then play a story according to the choice of the child. There is a screen that display the selected option before each choice. The Lunii fell and the screen is now broken.
      I'd like to repair it (probably just have to change the part, because the lunii still works perfectly fine) but I can't manage to identify the part/order it online. Do you have any...
      02-17-2025, 01:16 AM
