Sony Bravia KDL-60W855B
  • nomoresonys
    • 12323
    • U.S.
    Re: Sony Bravia KDL-60W855B
    that's good, now you have a good one to compare with if you are still curious.
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • patricksurry
      Sony Bravia XBR 55X900E cycling through test patterns: which board(s) to replace?
      by patricksurry
      We had a power outage but TV seemed to be working fine afterward. This morning it showed a "grainy" picture, and then next time we turned it on it's stuck in a test-pattern loop. None of the resets I've tried have any effect, including unplug/wait/plug in - it immediately goes into this cycling test pattern.
      Does this suggest the main board needs replaced? The TV is about 5 years old, picture still looks great (tho limiting to crisp red/green/blue/white lacks some variety ...
      04-08-2023, 06:45 AM
    • cheeky2
      Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
      by cheeky2
      For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
      See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
      01-08-2024, 05:56 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
