LG 55EG910V OLED TV clicking
  • dominik0801
    • Feb 2018
    • 98
    • Hungary
    Hi!
    I have the TV mentioned in the title. It won't turn on, just click.
    I have read many posts here and I tried the TCon/panel test, where I disconnect the motherboard and jumper the PSU on and connect +12V to the Tcon.
    The color pattern comes on, and the screen is perfectly fine.
    However, connecting the motherboard back, it only clicks again.
    I tried a CPU reflow, but the problem remains.
    After pressing the power button on the remote, the TV clicks ~ 3 times, then the Stand By LED fades away, like it's turned on. CPU gets warm, no picture on screen, backlight isn't on.
    All voltages seem to be fine on the motherboard (I can measure +12, +24, +3.5, +5).
    TCon also gets +12V, but only 0.7V on the backlight fuse. But when the PSU is jumped, the backlight also works fine.
    I made a jack-IR blaster, POWER_ONLY.wav however doesn't work, checking the IR LED with a camera shows no activity with that wav file. However, opening IN_START.wav makes the IR LED flash.
    Any ideas?
  • CapLeaker
    Leaking Member
    • 8327
    Re: LG 55EG910V OLED TV clicking
    disconnect the wifi module, see what that does.
    • dominik0801
      • Feb 2018
      • 98
      • Hungary
      No luck.. :/
      Same happens. I tried a serial-usb board connected to the TV's service output, but it only gives me trash information (boxes, questionmarks) on every baud rates..
      Could this be some kind of "protection mode"?
      Or maybe the motherboard is dead? And if so, what can go bad on it?
      • dominik0801
        • Feb 2018
        • 98
        • Hungary
        Here are some of the TCON test pattern colors however, so you can see, that the screen and TCON seems to be perfect. Also, since it turns on to play this little test pattern, it means that the PSU should be fine, am I right?
        • Diah
          • Feb 2013
          • 6436
          you have main boards issue.. disconnect yours T-CON and panel from system complete ( LVDS should be disconnected too ) by pass the PSU to turn on Power On Only ( no DRV_ON at this moment ) then feed the MB 12V and follow it if its dropped down . same way of test do it for 24V line on main boards...
          BTW yours reflow of the main ic could be did some things wrong too... need to rework BGA to be sure you are at the correct way.
          • dominik0801
            • Feb 2018
            • 98
            • Hungary
            +12V is not dropping, it stays at 11.9 - 12.0V.
            +24 is also stable.
            CPU gets quite hot to the touch, literally burning my fingers.
            I did multiple BGA reflows before and I never had any problems afterwards.
            • Diah
              • Feb 2013
              • 6436
              +24 is also stable.
              at which test its so hot 12 or 24 V test? it cant be both.. let please your answer absolute sure.
              this test mean no 3.5V goes to main boards . just to clarify
              • SaiBot187
                • Mar 2022
                • 17
                • Deutschland
                Hi, i got a LG 55eg9109, which is quite similar to 910V i think, with same behavior. No picture , no sound and after 3 relais clicks the PSU is on. I can measure 12v,24v,3,5v but at drv on 0V. With Jumper i got test patterns in different colors and no Pixel issues.
                With MB connected i got no Light at Optical audio. I measured some voltages at the MB and i would say the regulators are ok. Why the MB doesnt set drv_on on? Can someone give me a hint pls
                  • 12276
                  • U.S.
                  first thing i check whenever i get click click click is the solder joints on powerboard, might not be the problem but easy enough to check.
                  • Diah
                    • Feb 2013
                    • 6436
                    if the test was fine at stand alone test T-CON and panel.... try to power on only with Service remote see if the the optic come on or not.
                    • Diah
                      • Feb 2013
                      • 6436
                      Hi, i got a LG 55eg9109,Why the MB doesnt set drv_on on? Can someone give me a hint pls
                      Edid: this set are knowing too its goes to sleep mode. so no drv_on goes to PCB.
                      plug air mouse or any USB 2 mouse and other USB stick with with any movie file of mpeg after you plug them... turn on and keep move the mouse and click it... see if it will come on.
                      • SaiBot187
                        • Mar 2022
                        • 17
                        • Deutschland
                        I tested usb mouse and stick with mp4 file but No reaction of the tv.
                        Then tested power only mode but i would say its exact same behavior. No optical light...
                        • Diah
                          • Feb 2013
                          • 6436
                          upload clear focused high resolution photo of your mainboards. check if you can see micro switch on it MICOM reset. if it exist need to press it keep press and plug it in to reset micom chip
                          also if it response to RC on off. try send within service RC IN_STOP followed with code 0 4 1 3 to make hard reset.
                          • SaiBot187
                            • Mar 2022
                            • 17
                            • Deutschland
                            I tried IN_STOP followed by 0413 with LG service remote app on a samsung S6 but TV does nothing. On MB i cant find any switches. Is there anoter way to reset MICOM? Do you think i should try resolder MB or is it useless?
                            • lotas
                              • Jan 2016
                              • 4752
                              • Russia
                              Here are two pads for buttons that are not on the board.
                              You need to know exactly which one is responsible for the reset.
                              • SaiBot187
                                • Mar 2022
                                • 17
                                • Deutschland
                                Okay and the reset only press in standby or while i switch tv on?
                                • Diah
                                  • Feb 2013
                                  • 6436
                                  SW3000 are micom reset.. but yours MB design ignore this function as you have only 1 LVDS not double.
                                  disconnect this LVDS and turn on see the optical if it come on... you can plug USB or mouse to see if the mouse IR LED turn red. we need toknow if the 5V exsisit or not
                                  • SaiBot187
                                    • Mar 2022
                                    • 17
                                    • Deutschland
                                    I checked some voltages with help of circuit diagram and it seems all fine... whats wrong with this tv. xD I got 3.3V, 1.1V, 5V, 12V,24V at MB but it doesnt want to set DRV_On.
                                    i also got 3.3V at the optic jack but no red light??
                                    • SaiBot187
                                      • Mar 2022
                                      • 17
                                      • Deutschland
                                      I can measure 5V at USB 1/2 and while Power on TV my USB stick lights up but then nothing, no reading. USB Mouse do nothing, no light
                                      • Diah
                                        • Feb 2013
                                        • 6436
                                        do the test above i asked you please.. MICOM didnt send drv_on we will know why after the test.
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                          ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                          This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                          09-07-2024, 04:30 AM
                                          Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 16 OLED BSF-A3LA964SP Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 16 OLED BSF-A3LA964SP boardview and 16 OLED BSF-A3LA964SP schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 07:12 AM
                                          Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte AERO 14 OLED 9MF-E2USBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED 9MF-E2USBB4SH boardview and 14 OLED 9MF-E2USBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:40 AM
