jvc 32c670 smart no backlight
  • jimbofz
    • Apr 2013
    • 539
    hi tv respnds to remote and psu starts up 12v 24v ,boost voltage to backlight comes up to 85v then fades .backlight doesnt come on at all.
    theres no sound or trace of image even with flashlight test ,
    the backlights are ok with my led tester ,so i checked the volts on the main board theres a switched 5v and a 3.3v supply on v94 reg
    the psu is vestel 17ips62 ,ive downloaded two versions of this psu both have different led control ics my board has mp3398a
    the main board is type 17mb110p
    any ideas please
    • 12116
    • U.S.
    Re: jvc 32c670 smart no backlight
    Maybe start with testing the voltages at the connector on the powerboard with the cables all hooked up, it's the connector that the cable from powerboard to mainboard hooks into, most times there's a legend/map nearby that gives the expected voltages, you measure them with your mutimeter, set meter to 20 vdc then report them, put neg probe on chassis metal ground, pos probe on pin of connector, measure in standby take note, leave probes where they are then power on tv and again take note of voltages, report them here, example pin 1-ps-on-0 volts standby-power on-3.3 volts. A lot of the vestels aren't marked very well so it might be tough.
      • 12116
      • U.S.
      Video demo: https://www.youtube.com/watch?v=4v8DcqCNG4A
      • jimbofz
        • Apr 2013
        • 539
        as you say its very difficult ,as both boards are joined together
        i have soldered a wire to the back of the print to see if theres any volts on the inner row of the plug n skt ,ive established 5v ,5v switched 12v
        does anyone have a cct that uses the MP3398A led controller ?
        this would help to see why boost volts is turned off
        • jimbofz
          • Apr 2013
          • 539
          yes in the ideal world this would be possible but not on this vestel
          • zwarder
            • Oct 2013
            • 45
            • United Kingdom
            Check smd diode D42 i believe a RA159 1A 400-1000v
            I have these syptoms & believe this diode is short
            • sintv
              • Feb 2015
              • 37
              • scotland
              Have you checked continuity on board that strips plug into. Ive had that fault on a few 32in sets
              • triplefour
                by triplefour
                09-13-2023, 10:43 PM
              • Superbee_dad
                Sharp 80” long short flash backlight error - Help
                by Superbee_dad
                Hello Sharp TV experts
                Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                01-24-2025, 11:51 PM
              • DanPoka
                Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                by DanPoka
                I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                02-15-2025, 05:05 AM
              • Comp_Pro
                No Backlight Macbook A1990 820-01041
                by Comp_Pro
                Hello all,
                Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                Tests performed:
                There is no backlight even with a good screen.
                Backlight IC is receiving the correct support voltages.
                Fuse F8400 ok
                Current sense resistor R8400 ok
                Backlight IC is receiving 3.3V on enable pin.
                Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                Backlight IC receiving 5V from PP5V_G3S
                Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                05-06-2024, 10:23 PM
                HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch EliteDesk 800 i5-9500T Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch boardview and EliteDesk 800 G5 + Fitbit Versa Smart Fitness Watch schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                09-12-2024, 02:30 PM
