Pn64e8000 power supply
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    • Electronics/classic muscle cars
    I just ordered a used BN44-00516A power supply. I know they are prone to having cold/cracked solder joints, and I plan to spend a few hours touching them all up.
    Should I remove all the white caulk like crap from the legs of the fets? I think 5 of them have it on them.
  • JLCurve
    • Feb 2017
    • 32
    Re: Pn64e8000 power supply
    The silicon is there to mitigate dusty (smoker) environments. FETs handle relatively high voltages regarding to their gates. Dust can bridge Drain to Gate (and fry the fet). Silicon is there to mitigate cheap overall cooling design (no filter). Believe me, if Samsung could have done without the silicon smudges they would have! (in overall warranty repair costs)
    My advise is not to look for problems before they appear.
    Note that I don't know this particular model..
    Cheers,
    Curve514
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      I thought that over time the silicone turns conductive and will ZAP the igbt's and other things. I planned on removing it and replacing it with RTV black. It's used in the automotive field and great against heat.
        It's the old brown glue that is corrosive and conductive.
        I will not remove those white silicone unless you are going to replace the parts.
        You need to use electronics grade Silicone RTV (they are not cheap, I.E. https://www.gordonglassusa.com/group...e-Silicone.htm, https://www.americansealantsinc.com/...rade-silicone/)
        Read this about the type of Silicone RTV, if it smells like vinegar during curing do not use it.
        https://electronics.stackexchange.co...mponents/32812
        Subscribe to support us and access our Bios, Boardview, schematic search. It only takes 1 minute:
        https://www.badcaps.net/settings/subscriptions
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          Thanks Budm. I will concentrate on the bad solder joints then.
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
            03-31-2024, 02:12 PM
            07-01-2024, 06:34 AM
          • JimBanville
            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
            by JimBanville
            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
            09-13-2023, 07:21 AM
          • Amardillo
            Lecroy Power Supply PS1724 What is this Component?
            by Amardillo
            Lecroy power supply - this power supply is prone to failures. I have repaired mine a couple of times before. The problems with this power supply range from shorted out power mosfet, the green module pwm driver, aging EMI filter, shorted snubber etc.
            I once dismantled a custom component that I cannot identify, no way of knowing if it was the cause, and thus I have no way of checking it. However the power supply can still power up and supply properly without this component.
            This Component is not shown in the Schematic but apparently it is side piggy back mounted on the EMI filter as...
            12-22-2025, 01:15 PM
