I've replaced almost everything. i'm at a loss.
  • Jeryswan
    • Mar 2020
    • 39
    We replaced relay on power board. Replaced main logic. and replaced control board on this plasma TV. When we hook up power, a relay on the power board switches on then off and I can't figure why. any help would be amazing.
  • ducky29
    • Dec 2015
    • 369
    • Europe
    Re: I've replaced almost everything. i'm at a loss.
    Its very tricky with plasma tvs.Sometimes you must replace Z and Y both at the same time . I almost stopped doing them at my shop cuz they are very hard to make a profit.
    • wazzadj@hotmail.com
      Wazza
      • Nov 2017
      • 57
      Check your power supply board for shorts check your X & Y boards for shorts
      I had same problem.
      It ended up being Upper and Lower Buffer boards had Blown Diodes
      that took out the YSus Board that back fed into the X Main Board then the power supply board kept shutting down into protection
      Lots of Money spent on Boards replaced for a Repair on a secondhand plasma
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        I answered your PM. If the tv ran through the test patterns, everything is good EXCEPT the mainboard. A new ,or used good one will fix the problem.
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • ermals
          Samsung UN55H8000AF - No Picture, Working Backlight, Replaced T-Con Board
          by ermals
          Hi all!
          I've recently run into an issue with my Samsung UN55H8000AF LED TV displaying no image. I've done quite a bit of research in terms of what could be wrong with it. Below are the steps I've taken prior to reaching out here for some assistance:
          1. I've tried replacing the T-Con board (BN95-01594A), twice and have still experienced the same issue with all the boards I've tested with.
          2. I've tried to remove one side of the ribbon cable that goes from the T-Con board to the panel and still not getting any image on left or right side.
          3. I've checked voltages...
          08-01-2022, 10:35 AM
        • jb_Bak
          by jb_Bak
          CN6401
          Pin 01 NC
          Pin 02 NC
          Pin 03 "BL_ON": 0V
          Pin 04 "N/C"
          Pin 05 "STBY 3.3V": 3.5V
          Pin 06 "GND": N/C
          Pin 07 "AC_OFF"...
          09-27-2021, 04:52 PM
        • canadaboy25
          Panasonic TC-P54VT25 No image. A or D board?
          by canadaboy25
          I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
          The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
          I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
          01-17-2021, 01:06 AM
