Panasonic TX-58DXW784 main board
  • lospiratos
    • Jun 2020
    • 14
    • Belgium
    I'm looking for a new main board for a Panasonic TX-58DXW784. Unfortunately they seem to be not available anymore.
    Type TNPH1147 TXN/A1YJVE
    Will another TNPH1147 main board, but with another TXN number, also work in this television? I don't care if some functionality would be missing, as long as the hdmi ports work.
  • nomoresonys
    • 12201
    • U.S.
    Re: Panasonic TX-58DXW784 main board
    Maybe there? always make sure that the sticker numbers match when getting one to try to insure a match. will give link in both languages: https://translate.google.com/transla...search&pto=aue
    • nomoresonys
      • 12201
      • U.S.
      Original: https://www.replace4u.be/product/216...34-tnph1147-1a
      • lospiratos
        • Jun 2020
        • 14
        • Belgium
        Out of stock...
        • nomoresonys
          • 12201
          • U.S.
          Ok, my bad, guess I didn't look close enough.
          • lospiratos
            • Jun 2020
            • 14
            • Belgium
            I've ordered the mainboard of a TX-58DX750B now. That TV looks very similar. Hopefully it works...
            https://www.tvparts.co.uk/lcd-tv-spa...ic-tx-58dx750b
            • lospiratos
              • Jun 2020
              • 14
              • Belgium
              The TV works again now with the new 58DX750B mainboard, but I can only choose UK/Ireland as country, and English as language. Does somebody know how the region can be changed?
              Both regions apparently share the same firmware: https://av.jpn.support.panasonic.com...uk_cis_02.html, but I cannot reinstall it because the newest version is already installed.
              • nomoresonys
                • 12201
                • U.S.
                Maybe try a factory reset, then I think you can reset language, country etc.
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • ygorsan
                  by ygorsan
                  🧩 Problem Summary:
                  • I
                  07-28-2025, 08:34 AM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • JDC
                  by JDC
                  ONN 100012588
                  Long answer:
                  07-15-2022, 07:39 AM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
