STRANGE failure mode-Every other horizontal line is good, the others are intermittent
  • rysbrnr
    • Sep 2020
    • 3
    My Samsung 64" 3D plasma (PN64D8000FF) just started doing this one day. Everything else works fine and we're able to still use it for now. A couple weeks later I lost one horizontal line completely. It's been in this current state for a couple years now and has NOT gotten any worse.
    One day it was fine and the next is this strange issue of every other alternating line functions great.
    The other 50% of the lines will either:
    • work fine depending on color, some darker colors will perform better than lighter
    • sparkle effect
    • appear noisy ( snowy)
    • ghost images and latency
    I recently decided to open it up and here's what I've done so far:
    -replaced T-Con board
    -cleaned and re-seated ribbons from panel to Y-buffer
    -tweaked all of the voltages Vs, Ve, Vsc etc to match the original specs on the sticker (this made some noticeable improvements)
    I don't have a full set of test equipment at home other than my Fluke multi-meter, and an O-scope. (no ESR meter on-hand )
    Any ideas on what's going on with this? I can speak "electronics" if that can help someone help me, lol
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: STRANGE failure mode-Every other horizontal line is good, the others are intermit
    Will the set allow you to run a the test pattern. If there is a logic board/ or sometimes on the mainboard there is a set of Auto-Gen pads that you short.
    Pictures of your boards would be useful to identify how they all fit together.
    • rysbrnr
      • Sep 2020
      • 3
      I need to get an extra hand to help me lift this heavy tv off the mount and I'll see about getting some pics of the boards.
      When you're saying test patterns, are you referring to something like this? https://www.pcrichard.com/images/pro...rch%202011.pdf ??
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        Yes, that's how to run your test patterns.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4343
          • Italy - Milan
          D8000 series in lcd field suffers from bad CPU i think, plasma models i guess them shares almost the same board, so with the test pattern you probably has a first impression, then you can try a soft reflow, but a serious reballing can make the difference. But never experimented with this series!
          • Ihandyrepair
            Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
            by Ihandyrepair
            Hi guys
            I just started fixing 4k TV few months ago. so I am still learning a lot
            I got this tv from friend complaint is ghosting or horizontal lines on image.
            never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
            then it started to show the ghosting white image.
            I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
            it has 3 thin small boards at the bottom of the...
            12-05-2022, 04:18 PM
          • cubytus
            Samsung UN50TU8000FXZC shows thin horizontal green line when warm
            by cubytus
            Hi to all,
            I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
            I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
            Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
            01-10-2024, 01:26 AM
          • labello
            Lg43UJ620V horizontal line
            by labello
            Hi guys I have this tv and in one side of the pannel it shows some line i also cleaned the camble notting, although I found an smd capacitor on the pcb (there's no tcon on this model) but I can't find the same model thanks
            02-20-2025, 02:52 AM
          • labello
            by labello
            02-20-2025, 02:45 AM
          • dikei
            China Make TV with LG Display horizontal line at top and video freezes 1-3 secs
            by dikei
            Hi guys!
            I'm new to TV repair and just started looking into troubleshooting guides and other online info.
            Right now I have a Chinese make with LG display that is faulty. If I am not wrong I see two different problems here below.
            1. There is a line(white/multicolored) at the very top of the display that shows thinner sometimes and slightly thicker in some occasions.
            2. For any video the play freezes 1-3 secs and at the same time brightness goes low and returns to high when video continue to play.
            From my initial research...
            07-06-2023, 11:53 AM
