Apex LD 4088 backlight shut down
  • Hornnumb2
    • Feb 2011
    • 210
    I have this apex ld4088, the backlights will run for about 60 seconds and shut down, when they are working there is a slight buzz from inverter board. Power board is out putting the proper voltage. Standby 5v and the 24v to back light inverter board. 24v still present at plug on inverter when back lights quit. Thanks Michael
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Apex LD 4088 backlight shut down
    One of the lamps or transformers on the inverter board may be failing. You need to look very carefully when the backlights are on to see if you have a dimmer line across the screen where a tube may be failing.
    Do you still have an image on the screen when backlights fail if you shine a light on the screen and look carefully.
    • Hornnumb2
      • Feb 2011
      • 210
      Will check that tonight, I do have a led tester. I will test each strip to see what the draw is. Thanks
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        The set uses fluorescent tubes not leds and run at >1KVolts via the transformers on the inverter board
          https://www.badcaps.net/forum/attach...3&d=1601342388
          Are the Inverter board mounting screws missing?
          Inspect the Inverter transformers as suggested, also unplug the inverter board from the socket and inspect the inverter board fingers and the sockets.
          • Hornnumb2
            • Feb 2011
            • 210
            Ok I took the screws out to remove cover. Is there a way to check the output going to each tube? I looked that board over and didn't see anything that looked burnt. I don't have the screen off, is there anything else I can test before doing that? Thanks
            • Hornnumb2
              • Feb 2011
              • 210
              If I were make up a led conversion kit for it, is there any reason some shorter strips couldn’t be ran vertical instead of horizontal?
              • Hornnumb2
                • Feb 2011
                • 210
                Just checked it and still have image on screen when backlight quits.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  Can you check the winding resistance of each of the inverter transformers and compare them to each other.
                  You said the set powers up briefly so are you able to see if there is a lighter band across the screen where one of the tubes may be failing?
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    these testers work well i have one myself
                    https://www.ebay.co.uk/itm/100-NEW-C...wAAOSwZ6tfRMou
                    this video maybe worth a watch shows how too test ccfl and also the transformers
                    https://www.youtube.com/watch?v=KCTVaW2XQ1o&t=1233s
                    • Hornnumb2
                      • Feb 2011
                      • 210
                      Which terminal do I test across in this pic? https://www.dropbox.com/s/lkcm3859pj...D4D00.png?dl=0
                      1 and 3?
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        1 and 3?
                        It's better if you could attach any photo's to your post using Add Attachment. Dropbox wants you to sign in.
                        What's the inverter board part number?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          There appears to be 4 solder points on each transformer.
                          If you label them 1 to 4 then test
                          Transformer 1
                          Pin 1 - 2
                          Pin 1 -3
                          Pin 1 - 4
                          then
                          Pin 2 - 3
                          Pin 2 - 4
                          then
                          Pin 3 - 4
                          Transformer 2
                          And note the resistance carefully for each test and for each transformer 1 to 10.
                          It would also be worth looking on the underside of the board to see if there is any sign of overheating. Board tends to brown.
                          • Hornnumb2
                            • Feb 2011
                            • 210
                            Here is the pic, I saw one video that grounded the feedback wire to stop the shutting down. Do you know which one off the transformer is feedback?
                            • Hornnumb2
                              • Feb 2011
                              • 210
                              Ok here we go.
                              1) 1-2 8.45 2) 1-2 8.27 3) 1-2 8.67 4) 1-2 7.9 5) 1-2 8.67
                              1-3 .03 1-3 .03 1-3 .03 1-3 .02 1-3 .03
                              1-4 8.3 1-4 7.09 1-4 7.8 1-4 8.62 1-4 8.3
                              2-3 8.4 2-3 8.38 2-3 8.01 2-3 8.5 2-3 8.3
                              2-4 .4 2-4 .4 2-4 .4 2-4 .4 2-4 .4
                              3-4 8.6 3-4 8.07 3-4 8.39 3-4 8.56 3-4 8.1
                              6) 1-2 8.67 7) 1-2 8.1 8) 1-2 7.8 9) 1-2 8.0 10) 1-2 7.9
                              1-3 .3 1-3 .3 1-3 .3 1-3 .3 1-3 .3
                              1-4 8.01 1-4 8.5 1-4 7.8 1-4 8.2 1-4 8.0
                              2-3 8.4 2-3 7.9 2-3 8.5 2-3 7.6 2-3 8.0
                              3-4 8.15 3-4 8.1 3-4 8.1 3-4 8.5 3-4 7.9
                              • Hornnumb2
                                • Feb 2011
                                • 210
                                Well I had them in columns but they didn't stay that way.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Can you recheck some of your readings and were they ohms, Kohms or Megohms?
                                  The transformers usually have a minimum of two windings on them so if one set of windings were labelled 1 and 2 and the other winding was 3 and 4 then you would expect a resistance reading of eg ohms for one set of windings and maybe 10's if not 100's of ohm for the second set of windings
                                  • Hornnumb2
                                    • Feb 2011
                                    • 210
                                    Across 1-2 readings are K ohm
                                    1-3 is ohm
                                    1-4 is mega ohms
                                    across 2-3 readings are mega ohm
                                    2-4 k ohms
                                    3-4 is mega ohm
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      I'll assume that Pins 1 - 3 where it changes half way down is a typo.
                                      The ony odd reading is T4, Pins 1 -3 @ 0.02 which could be an error in the reading but worth rechecking.
                                      Can you also recheck Pins 2- 4 of each transformer with your meter set to ohms and post back the results.
                                      • Hornnumb2
                                        • Feb 2011
                                        • 210
                                        I appreciate all the guidance, I went ahead and ordered some led strips and will convert it over. I am going to start a new thread to discuss conversion. Thanks
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • jimbofz
                                          lg 32LC46 backlight inverter board fault
                                          by jimbofz
                                          Hi this oldie had no backlight .after replacing caps on 24v rail ,
                                          still no b/l this uses inverter type:1315 B1-16A,
                                          im sure ive come across the same inverter in a samsung possibly le32r88bd ?
                                          all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
                                          this allows protect to be temporary overridden.
                                          b/l now comes on
                                          but the left hand side of pic is gradually darker than the right side
                                          i have the cct for the tv
                                          but it does not have inverter cct.
                                          i opened it up to inspect the ccfl tubes
                                          and they dont have any...
                                          12-19-2021, 06:58 AM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
