LG 55B6P OLED No image/sound
  • Diah
    • Feb 2013
    • 6348
    Re: LG 55B6P OLED No image/sound
    yes so now we have the micon reset complete.
    now turn it on and check on USB 1 2 3 do you have 5V?
    • blkrx7
      • Oct 2019
      • 24
      Turned on
      0v on USB 1, 2, 3
      • Diah
        • Feb 2013
        • 6348
        okay... you need to check on the socket P2500 wich come from PWB pin 3 4 5 6 had 24V or less
        • Diah
          • Feb 2013
          • 6348
          also locate IC2305 (DC to DC )on MB and shoot clear photo of it and round parts such IC4301 IC4400
          • blkrx7
            • Oct 2019
            • 24
            P2500
            24.56 on Pins 3, 4, 5, 6
            New IC's attached
            • Diah
              • Feb 2013
              • 6348
              so if you check IC4301 IC4400 pins could u find 5V ?
              • blkrx7
                • Oct 2019
                • 24
                IC4301
                IC4400
                1 -> 5v
                2 -> 0v
                3 -> 0v
                4 -> 3.3v
                5 -> 0v
                6 -> 0v
                IC2305
                15,16,17 -> 12v
                18 -> 0v
                These aren't easy to measure, if something looks way out, yell.
                • Diah
                  • Feb 2013
                  • 6348
                  so 2305 working..
                  now i want you to remove the socket on the T-CON driver which it come from PWB 24V socket.. turn on and give notice on Audio optic lit red or not... give time 1 minute
                  • blkrx7
                    • Oct 2019
                    • 24
                    Unplugged from wall
                    Removed P202 from Power supply
                    Plugged into wall
                    Turned on
                    Waited 1m
                    No Optic LED light
                    • blkrx7
                      • Oct 2019
                      • 24
                      Strange, usually I get 1v on the 24v rail (measured on power supply).
                      When 202 is unplugged, I get 0v
                      The fuse on the tcon (measured good) reads 1v on either side. I presumed it was the power supply sending that 1v, but it seems like it's being backfed somewhere on the tcon.
                      • Diah
                        • Feb 2013
                        • 6348
                        sure if 202 unplugged you will get 0V on t-con side but 24 on PWB
                        and if its plugged how much it read on T-CON side?
                        • blkrx7
                          • Oct 2019
                          • 24
                          1v
                          202 unplugged
                          Power supply output pin 0v
                          Tcon power input pin 1v
                          202 plugged
                          Power supply output pin 1v
                          The 1v is coming from the tcon. May not be relevant but surprises me to see any voltage on that pin at all while it's unplugged.
                          It's actually 1.336v, very strong, very consistent.
                          • Diah
                            • Feb 2013
                            • 6348
                            the main boards didn't sent signal to turn on the panel 24v rallies on PWB.
                            • blkrx7
                              • Oct 2019
                              • 24
                              Yep, I can bridge the P201 pins 24 (drv_on) & 17 (stby) and confirmed the power supply outputs 24v (tcon/mb unplugged from power supply).
                              That signal is not getting sent from the mainboard.
                              Would you like me to bridge it while it's connected to the mainboard/tcon?
                              • Diah
                                • Feb 2013
                                • 6348
                                can you show the pins print label of the sockets which goes from PWB to MB?
                                • blkrx7
                                  • Oct 2019
                                  • 24
                                  See attached
                                  • Diah
                                    • Feb 2013
                                    • 6348
                                    you can do it but only in this way... if pin 24 are drv_on trace the cable of it which it come from MB.. cut it in the middle then bridge pin 24 with stb put back socket 202.. and turn on and put your eyes on the screen and the audio optic if its turn red
                                    BTW: of course we are talking on the bridge only at PWB side
                                    • blkrx7
                                      • Oct 2019
                                      • 24
                                      Unplugged
                                      I removed pin 24 completely from p202, so it would not connect to power supply.
                                      Jumped 24/17 on the power supply
                                      Plugged in
                                      Turned on
                                      I have 24v at the tcon now
                                      No optic LED or anything on the display
                                      • Diah
                                        • Feb 2013
                                        • 6348
                                        screen black? play your PC hdmi
                                        • blkrx7
                                          • Oct 2019
                                          • 24
                                          Laptop plugged back in, still nothing on the display, no voltage at usb.
                                          Laptop still reports back it's plugged into an LG display.
                                          • Ierwin
                                            by Ierwin
                                            05-13-2025, 03:31 PM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                            ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook Pro 15 OLED Specification for Upgrade or Repair
                                            This specification for the ASUS VivoBook Vivobook Pro 15 OLED D3500QC-L1351W Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Vivobook Pro 15 OLED D3500QC-L1351W boardview and Vivobook Pro 15 OLED D3500QC-L1351W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 04:30 AM
                                          • Kartowl
                                            philips 47pfl6158k/12 image faded away, sound still coming from TV
                                            by Kartowl
                                            Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                                            04-23-2024, 12:57 AM
                                            Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook Specification for Upgrade or Repair
                                            This specification for the Gigabyte AERO 14 OLED BMF-72ESBB4SH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 OLED BMF-72ESBB4SH boardview and 14 OLED BMF-72ESBB4SH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 07:12 AM
