sony KDL 40R483B 6 blinks
  • jimbofz
    • Apr 2013
    • 539
    Hi need some help with this one, tv has external psu 19.5volts .
    powers up backlight comes on ,
    front led goes green ,sony welcome logo appears
    then backlight goes off and 6 blinks .
    ive tried various reset procedures with no luck
    the internet advice is that 6 blinks is due to backlight problem
    and like most led tvs backlight should be reduced as much as possible in the settings menu.
    but cant adjust backlight until tv will stay on " catch 22"
    cant find any service procedures specific to this model for reset
    this is the first "one board" model ive seen ,
    the main board seems to contain t con, psu regs ,and i/p interface
    ive looked at the sony website but theres nothing specific to this model
  • diif
    • Feb 2014
    • 6978
    • England
    Re: sony KDL 40R483B 6 blinks
    A software reset won't do anything if any LEDs have failed.
    You need to either test the voltages at CN9000 at switch on, strip the panel down and check visually or use a decent (300mA) LED tester to confirm.
    • jimbofz
      • Apr 2013
      • 539
      thanks for info .
      the voltages in cn9000
      rise up to 20v then fall away to around 3v
      for the brief moment when backlight is on its around 20v
      except for the last pin on right ,this rises to around 40v then falls away
      what confused me was that the backlight does come on ,
      i thaught they either work , go o/c, or s/c,
      in which case i wouldnt expect them to come on at all
      • neilc6
        • Nov 2015
        • 1550
        TV is going into protection shutdown because shorted LEDs are detected which cause undervoltage. I have seen posts were the error signal is bypassed to keep the backlights on but shorted leds can damage the power supply or causes a fire. Proper repair is to replace all the strips with new and turn down the backlight level.
        • jimbofz
          • Apr 2013
          • 539
          thanks ill crack it open and test all led strips
          • jimbofz
            • Apr 2013
            • 539
            ok stripped down to find one led s/c .
            there are two strings of 5 strips each with 5 leds.
            i assume that there is a comparator type cct that compares the current drawn between both sets of led strings, and as one string has a s/c diode the current drawn will be different .
            these leds are 3v but have built in zener for foreward current .
            i have a selection of leds but none have the built in zener
            (meter on diode test one way led lights then, reverse leads reads 950.)
            for some reason the strips all look the same
            but some are marked A and some B
            any ideas where i can buy these leds with zener ,as i can remove and solder in replacements
            • diif
              • Feb 2014
              • 6978
              • England
              A standard two pad LED ? I think it's measuring like that as it's in circuit.
              • jimbofz
                • Apr 2013
                • 539
                all the working leds have a reverse reading on diode test mode of my meter .
                i have found a suitable led and fitted it ,
                all strips now light with external supply
                also tested on 200meg ohm range all leds read 4.9meg one way and 1.2meg the other
                all plugs and skts checked for dry joints . chain is not o/c ,
                reassembled
                and true to my luck fault still exactly the same .
                so now i suspect the cct that feeds the leds
                not producing enough volts to drive the leds
                any ideas please?
                • neilc6
                  • Nov 2015
                  • 1550
                  You either have another bad LED or your substitute LED has the wrong voltage. The TV should turn on with the panel disconnected. I always power up the TV and check that all the LEDs come on before reassembling the TV. You should also check with the diffuser panels replaced as well for bright spots and dirt.
                  • jimbofz
                    • Apr 2013
                    • 539
                    i agree but with this sony it
                    will revert to 5 blinks if turned on with panel removed ,
                    but it will stay on long enough to visually check leds for even brill levels ,
                    surely if led i fitted was wrong volts it would light differently from all the rest ie dimmer or brighter?
                    thanks for your tip
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      any ideas please?
                      Measure the voltages at CN9000.
                      • jimbofz
                        • Apr 2013
                        • 539
                        still same as post 3
                        • jimbofz
                          • Apr 2013
                          • 539
                          good news fault traced to poor connection on one of the plug in led strips,
                          sounds simple but it was a pig to trace ,
                          as when i used meter to check
                          i was putting slight pressure on the connection making it good
                          with panel removed you only have a few seconds before the set trips out ,
                          after a lot of head scratching i found i could cause a strip to flicker on and off which was enough to cause the sensitive control cct to activate
                          there was no sign of overheating ,
                          but a quick resolder of the plugs and skts ,and also cleaned and tinned the copper connections to ensure a good tight fit on each strip
                          thanks for all people who tried to help
                          • odie34
                            Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                            by odie34
                            I am a hobbyist (not a professional) so please be gentle...
                            I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                            I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                            02-18-2024, 09:11 AM
                          • triplefour
                            by triplefour
                            09-13-2023, 10:43 PM
                          • AK_777
                            Sony KD-65A1 Repair – 4 Red Blinks Error
                            by AK_777
                            Hi everyone!
                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                            02-20-2025, 04:15 PM
                          • jchon
                            Sony A1e 5-blinks help
                            by jchon
                            Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                            I found the service manual, which was critical to know where to probe.
                            https://www.manualslib.com/manual/20...1e-Series.html
                            With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                            Unfortunately the 5-blinks...
                            06-28-2023, 11:52 AM
                          • Nicktronic
                            Sony XBR-65X850D 2 Red Blinks
                            by Nicktronic
                            I have the subject TV and it will work normally sometimes but suddenly go black and give the 2 red blinks blink code. When this happens, I check the power supply board voltages and all I have is the Standby 3.3V and BL_ERR 2.2V. When it's working normally, all power supply board voltages look normal and stable. I've checked the backlights with a tester and they all test good. I've also read that the 2 red blinks is a faulty power supply board, so could it be throwing up an erroneous BL_ERR?
                            Any Sony experts out there that can help??...
                            11-19-2023, 06:51 AM
