picked up this tv. The guy said storm killed it. I checked power supply and many of the components failed testing and also no sound with new power supply but I am getting power to main board. I'm wondering if I received a bad power supply because no standby light.
Vizio V705-G1 no power
Tags: None
Re: Vizio V705-G1 no power
so I replaced ps and the it sensor board and ribbon cable got very hot. storm took out it board also? -
1) Please attach good clear pictures of the whole backside of the TV showing all the boards so we can see what we are dealing with.
2) Report the Voltage readings you have done.
3) Show us the Sensor board.Never stop learning
Assuming...7 Photos -
by SoulzinkHi everyone,
I am trying to fix a samsung washinmachine power supply main board.
I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
The power supply board reference is the following: DC41-00189a
I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by sam_sam_samI was working on this CNC machine today found no keyboard functioning no control relay powering on
The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
Found shorted diodes on main controller relays there are 3 of them that... -
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... - Loading...
