Samsung 64" Plasma BN44-00516A PSU Repair
  • Gandalf_Sr
    • Sep 2020
    • 7
    This is a PN64E8000GFXZA TV that I've had for about 8 years. It has occasionally 'glitched' where it would go off periodically and then come back on with no issues for weeks. Last week it went 'pop' while my wife was watching it and then it runs up past the splash screen, but then as soon as it displays an actual picture for maybe 1 second, it does the click, power cycle and keeps going around that loop, picture appears, and then it reboots.
    So we bought a new TV but, being an EE, I wanted to check the blown one out. I took out the SMPS PCB which is BN44-00516A and, straight away, I could see that one of the pins of the QP802 FET was burnt, see picture. The source pin which goes to ground was open cct from the PCB because the track had blown around it roughly where I've drawn a red circle (see 2nd picture). [EDIT] I measured the FET after removing it and it's single-digit ohms between any 2 pins so it has clearly applied high voltage to the components on the source and gate pins although the source is directly to a big ground track which is why it blew the copper around the pin; the gate obviously tried to feed high voltage to RP803 & RP804 and they are open cct too.
    I can't find a schematic for the BN44-00516A but I've found the cct for the BN44-00333A and the circuit for ICP801 driving QP802 & QP804 on my PCB seems very similar to the 333A schematic where ICP801 drives QP802 & QP803. If anyone can provide the actual 516A schematic that would be great.
    It appears that the circuit is a dual phase switcher where the cct associated with QP802 is the same as that associated with QP804 but, in my bad PCB, many of the components between QP802 and the push-pull pair QP807/8 are blown e.g. R803/4 are both open circuit (5 Meg).
    I've ordered a repair kit that includes many major parts but the concern is that ICP801 is blown or at least the side that drives QP802 may have been damaged.
    I'll end this post here but any input, advice or comments are welcome and appreciated.
  • Gandalf_Sr
    • Sep 2020
    • 7
    Re: Samsung 64" Plasma BN44-00516A PSU Repair
    So, to summarize and keep going, I figured that ICP801 is actually running but may be damaged too - then I found a repair kit at tvrepairkit which includes the following parts:
    Fuses (2) FS801S, FM802S
    Transistors (4) QS802, QS804, QP804, QP802
    Integrated Circuits (4) IC801, UQ802, US801
    Diodes (1) DP802
    Capacitors (4) CS825, CX802, CX851, CX857
    But I will also need Replacements for the following:
    Transistors QP807, QP808
    Diode DP807
    Resistors RP803, RP804, RP813, RP810
    Capacitors CP811, CP832
    Inductor LF802
    I've tested RP814 and it seems fine at 10 Ohms so I'm hopeful that the IC is OK but if I get the right one with the kit, I'll replace it anyway.
    The kit I purchased includes the IC but I've heard that it may be a PIC microcontroller and that it needs programming, I can do the programming no problem but where would I get the code from? I'm not even sure that it is a PIC and I've attached a picture showing makings as follows...
    21A5P4M SPC1012T G4
    and searching for SPC1012T reveals that it's a Power Factor correction IC so maybe the one that comes with my kit is going to be a drop in replacement?
    Can anyone help me out with the Transistors QP807, QP808 and diode DP807 identification? I don't want to assume that they are the same as shown on the 333A schematic.
    Thanks in advance for any help you can give.
      • 21582
      Regarding the microcontroller see the posts 22 and 27 in this thread - https://www.badcaps.net/forum/showth...-00516A&page=2
      Those posts were from 2017 so i don`t know if anyones found a fix since then .Surely the PIC in the kit should be pre-programmed ?
      • Gandalf_Sr
        • Sep 2020
        • 7
        Thanks, I read that and was probably getting mixed up as they are talking about UQ802 which is a voltage controller. I am pretty sure that my ICP801 (SPC1012T) is not a PIC - it has no Microchip marking that I can see and it's available all over the place for around $5 including on Amazon. So, assuming that is the part that comes with my kit, I will just change it out.
        Right now, I'm working through the parts in the drive circuit between ICP801 and QP802 and many are bad, QP808 is bad, it's a KTM2907 on the 333A schematic.
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          I recently replaced a BN44-00515A power supply due to cracked solder joints on the FETs attached to heat sinks. I tried a re-flow of the solder joints but the FETs were already stressed from the bad solder joints and fully failed after the re-flow.
          I got my Power Supply from ENCOMPASS.COM for about $130.00 after I turned the core in to them. The one I got was new, but they might have a factory refurb board too.
          They call me......."threadkiller"
          • Gandalf_Sr
            • Sep 2020
            • 7
            Thanks, I'll bear that in mind.
            I now have the parts from Digikey plus the other parts from tvrepairkit arrived today. I should get to this this week.
            • Gandalf_Sr
              • Sep 2020
              • 7
              So a quick report is that, I fitted the parts today and fixed the problem. I had to replace the SPC1012T power factor correction IC along with the push pull pair of driver transistors and twin diode which were not part of the repair kit.
              I'll update this post with the details of all the parts I used as they may be handy for others.
              • Gandalf_Sr
                • Sep 2020
                • 7
                Here's the fuller update promised. See the attached marked up schematic which is not actually for the BN44-00516A, it's for the -00333A but it's the only one I could find (from this forum) and it's close enough to understand what was going on. I haven't marked all the components but those I have marked or checked match the reference designators on the 00516A PCB.
                What I believe happened was that QP802 failed (it was marked HAE147 but the not failed QP804 was marked HAX147, I couldn't find either part number but is the E part a lower voltage rating?) and went short cct between all pins, the main fault current flow was to ground (FET source) which explains why the PCB track around that pin had vaporized. Now we had VAC_A connected to the right hand side of LP802 and the whole chain back through DP807, QP807, QP809, and ICP801 got zapped, the weakest links failed so that when I went through and tested, the following components were damaged:
                QP802, single digit ohms between all pins
                RP803, RP804, RP810, open cct
                QP807, QP808, open cct (high M ohms)
                LP802, DP807, RP815, CP811 all tested good.
                The fact that the TV was working and then looping through multiple power resets when asked to display a bright picture suggests that there was half of the PF correction circuit working indicating that ICP801 and QP804 were good. However, as the repair kit I bought for $35 included ICP801, QP804, DP801 and several other caps, I changed them too. While I had ICP801 off the PCB, I tested the surrounding components on the QP804 side and found that they all tested good.
                You can see on the lower right of the schematic the part numbers I replaced; QP807, QP808 are the same number but different prefix. I measured the forward voltage of the working DP807 and made a guess at a substitute in terms of voltage and current, it seems to work.
                I tried to run it up on the bench but never got VS or VA to come on despite grounding VS_ON - there's a comment in the Fast Track Trouble Shooting Manual that says that VA, VS won't come on unless they are loaded in some early models - so I threw it back in the TV, crossed fingers, and powered on! All seems to work just fine.
                RP804 should be 3.3 Ohms, not 3.3k
                • ArMaaN376
                  Samsung PS51E550 Plasma TV
                  by ArMaaN376
                  I am having Samsung PS51E550 Plasma TV. While the TV was working, a crackling sound heard & video went off with audio still ON. After switching it off & ON, the red LED on TV blinks six times & then off.
                  Opened TV cover & observed foll
                  a) Green LED on the small PCB blinks at @5-6sec ON & off for 3-4 secs. Red LED on logic board ON
                  b)Vs & Va on power supply board raises momentarily to 209v & 58v resp & then drops.
                  c) Cold test on Y-main board shows all 3 pins of FGPF4536 IGBT short to Grnd.
                  How to confirm Y -Buffer board...
                  06-19-2024, 04:05 AM
                • jm1234
                  Panasonic plasma TX-P42ST50 - 6 blinks
                  by jm1234
                  anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                  It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                  I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                  I checked that board for any obvious faults...
                  05-22-2024, 06:59 AM
                • nicdev007
                  Samsung BN44-00445C power supply issue
                  by nicdev007
                  Hello all and thanks for the great welcome to the forum!
                  With the help of multiple community members and some of my own experience I have advanced on the repair of a Samsung PS59D530A5 TV. The power supply - PFC card number is BN44-00445C.
                  At first the PFC MOSFETS where blown along with a host of other SMD components including the PFC controller IC (20 pin R2A20118). I replaced all components found in a kit form, to be sure (F801S,QP802, QP804, DP802, QP806, QP808, QP805, QP807, RP815, RP806, DP804, DP807, RP803, RP807, RP804, RP808, ICP801). Attached a picture of the components...
                  04-28-2022, 03:25 AM
                • KYBOSH
                  Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
                  by KYBOSH
                  Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
                  No picture but you hear the TV static (white noise) playing loud and clear.
                  The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
                  But it seems they didn't get too far and just left it.
                  When I first took a look I was amazed at how pristine the inside looked.
                  Its as if the TV had been in a time capsule.
                  Caps looked like they were just pulled off the self.
                  Copper coils had no sign of corrosion on...
                  02-01-2023, 11:10 PM
                • chazh
                  LG 60PS11-UA 60-inch 1080p Plasma TV-service lit & video help needed
                  by chazh
                  This is my first posting, so forgive me everyone in advance if I made mistake(s) in my posting.
                  I know there have been much about this plama tv already and I have read through most what I could find. However; I still have not come across any service lit/schematics for this tv. I even looked for the 50PS11 which would be basically relevant other than display size. Anyone know to find the documentation would greatly be appreciated.
                  The set that I have has issues with lower third of screen being dimmer than the above portion. From my past experiences with tube, solid state,...
                  09-01-2025, 08:56 PM
