Frozen at first instulation language screen
  • l3emarsh
    • Jul 2020
    • 28
    • england
    I have put the code in for the remote control wrong and loaded the profile and now I am stuck at the language screen at first instulation aaaaaaggggggghhhhhhhhh!!!!!!!!!!!!!
    VESTEL 17MB130S BOARD
    I changed it to KAS49128 which is a Panasonic r/c but I now think that is just a model number for the r/c and not the correct code?, I was using it on RCA_43XX_RC5 UNIVERSAL R/C
    FUCK, Please tell me there is a way out of this as I have tried Vertual remote and usb mouse and neither worked??? when I had a keyboard last time this happened it moved the cursor around but the enter key did not select a choice, in fact not one key on the whole keyboard selected a choice so I was stuck then, I have tried every code in the universal remote and it won't work so I think I have frosen it now!!! BOLLOX I AM SUCH A DICK HEAD.
    PLEASE HELP???
    If any one knows a way out please help, even if the board has to come out.
    I have firmware files to re-flash or download it onto board but no ok or enter key to get it to accept the software at first power on??? and I changed the profile back to the one I was using but also cant get into it to upload them???
    Help Please????!!!!!!! Lee.
  • Diah
    • Feb 2013
    • 6341
    Re: Frozen at first instulation language screen
    again notice this. yours mb130_hwprofile.bin you uploaded over here.. it show under USBPorts -- Number 0x00000001 mean the finlux firmware had only one usb.. infact yours tv havve 2 or more i guess.. so only one USB socket will work... this why you need to use usb hub so you can try the mouse and usb of firmware at same hub.. ( working socket)
    so try this to play OK key on the tv in order to flash complete firmware again hope this will help
    1- use wired USB mouse in the tv and press on the mouse the left Key ( keep press ) while you plug the tv in wall socket.
    2- connect the tv with LAN cable , and download from google store Vestel Smart Center to use the net work remote OK key.
    your tv are blind now.
    • l3emarsh
      • Jul 2020
      • 28
      • england
      yes the tv is blind and i am out of idea's, i am still trying to connect toolbox through LAN but it won't connect and i am wondering if i do it wrong.
      can you tell me correct way and do i enter MAC of TV or the IP the TV was using on my network?
      Thank's lee
      • Diah
        • Feb 2013
        • 6341
        Thank's lee
        tools need the IP address of the tv. but as you are now at first page of first installation i think the TV will signed to the IP only after passing Network installation.
        this why you can use USB to UART adapter or also programmer if you have CH341A by changing the jumper to become serial adapter.
        using the TV RX to Adapter TX & TV TX to Adapter RX. you will be able to flash firmware... or switch the ftp on all by command..
        best place for you xda-developers forum for example. you will find allot of stuff to learn how to.
        • l3emarsh
          • Jul 2020
          • 28
          • england
          picture of my board.
          Lee.
          • Diah
            • Feb 2013
            • 6341
            Lee.
            easy to find the rx and tx and connect serial to communicated instant of remote control by command
            see attached pdf which command to send via rx and tx points to take full control on the set.
            • l3emarsh
              • Jul 2020
              • 28
              • england
              To All Please!!!
              I have to replace my main board which was a 17mb130s running VES550QNYS-2D-NO1 for a Panasonic TX-55FX555B 4K HDR Smart TV.
              My question is that I have a resently instaled sky dish not being used so can I upgrade my board to the one that takes a dish and what channels extra would I get?
              Also what is the better one to get? 130s-140s-or-211s board with dish compatability?
              And what firmware would you run on it?
              I am ordering tonight so please help???
              Many Thank's, Lee.
              • BMCappelletti
                Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                by BMCappelletti
                Hi everyone.
                Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                02-18-2025, 12:22 PM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • smic717394
                by smic717394
                07-25-2024, 10:16 AM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • ipatch
                ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                by ipatch
                i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                08-24-2024, 02:36 PM
