Samsung plasma - flashing standby light
  • 7ony
    • Aug 2020
    • 9
    The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
    Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
    Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
    No visible cracks in the panel so I started by pulling out the power board and checking voltages. Everything seemed within spec. VA was 56.7v and VS was 212v, but I have no idea if those numbers are good because I haven't yet identified the table on the board itself or a service manual.
    EDIT: Found the table on the back. It says VS should be 200-215v and VA should be 54-62v, so my readings (212v and 56.7v) were within range.
    I replaced all but the biggest 3 or so capacitors as well but nothing has changed--it still does the flashing standby light.
    Hopefully it doesn't need a new main board since buying a replacement at ~$150 wouldn't be worth it. Any suggestions on what to try next? Thanks.
  • R_J
    • 9549
    Re: Samsung plasma - flashing standby light
    Search the forum with your model, there are other threads about this, If you are getting the VS and VA, the power supply is ok and likely the mainboard is also ok (if bad the tv would likely not turn the PS on) You could have a bad Ysus or bad buffer board
    • 7ony
      • Aug 2020
      • 9
      Hi, R_J. Thanks for the reply.
      How can I be sure that the mainboard is turning on the PS? When I did voltage testing, I had the power board removed from the TV completely and I just jumped the PS_ON pin to ground, and before I checked VA and VS voltage, I jumped the Vs_ON pin to 5.3v. I never checked voltage with the power board hooked up inside the TV because I couldn't access the pins once everything was hooked back up.
      Though, with the power board installed, there is a green LED light on the mainboard that flashes along with the standby light.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        If your y main looks like this one, replace this capacitor. It's a 10uf 50v.
        • 7ony
          • Aug 2020
          • 9
          maybe it's my browser but I'm not seeing any images
          • R_J
            • 9549
            I missed the "pulled the power supply and checked the voltages". You could check the PS-ON voltage with the mainboard connected, and see if it changes when the power button is pressed, Can you access J875 on the power supply board?
            I believe there are 3 blue 10µf/50v caps that need to be changed on this Ysus board, I don't remeber which ones they are, tvtimmy likely knows which ones they are.
            One might be C5162?
            • 7ony
              • Aug 2020
              • 9
              Is this the y-main cap (106 at C5162) everyone is referring to (in this thread and this one and this one)?
              https://www.digikey.com/product-deta...CT-ND/12760769
              EDIT: no, that is definitely the wrong part. I didn't notice that it was surface mount.
              I'm not seeing ceramic caps on digikey that are 10uf at 50v. Would it be a bad idea to swap it out for an electrolytic cap?
              EDIT 2: I was in the wrong section. Looks like there are plenty of 10uf 50v ceramic caps
              https://www.digikey.com/products/en/...=1&pageSize=25
              • 7ony
                • Aug 2020
                • 9
                Yes, I found J875 and checked the voltage in standby mode and while pressing the power button. In standby it read about 3.2v, and when I hit the power button, it jumped up to 67.6v.
                • R_J
                  • 9549
                  I doubt that it jumped up to 67.6v, likely down to 67.6 millivolts. Is your meter autoranging?
                  • 7ony
                    • Aug 2020
                    • 9
                    Yes, you're right. I didn't notice that the meter display switched from V to mV. Now the true level of my noobness has been exposed.
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      Oops, here is the picture.
                      • 7ony
                        • Aug 2020
                        • 9
                        Thanks. I just ordered 10 of these replacements: https://www.digikey.com/en/products/...465-ND/2815395
                        • JLCurve
                          • Feb 2017
                          • 32
                          If you replaced the 10uF caps and still the cpu board drops all voltages after 2-3 sec upon power-up, you most likely have a (few) Y-buffer chips dead. These chips work with 12V but their ground is actually at -200vdc. The DIP8 and 10uF does the regulation for the "positive" supply (-190V?), called Vsch by Samsung.
                          Y-Buffer chips may die shorted and the CPU will power-down all voltages (your case?) or die open (inoperative lines on the screen).
                          Check this video for testing Y-Buffer boards for shorts :
                          https://www.youtube.com/watch?v=Iw0_wFwbij4
                          Chips are generally available on Aliexpress but the PCBs are so bad quality your soldering skills have to make up for it!
                          As always, if I say crap please correct me.
                          Cheers,
                          Curve514
                          • 7ony
                            • Aug 2020
                            • 9
                            Just wanted to post an update for anyone else who might come across this thread in a search... I got the panel working (it looks amazing) and it turned out to be the ceramic cap in the picture posted by tvtimmy.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              Thanks for the update.
                              • Bloopeta
                                Samsung UE43KU6400U Flashing Red Standby Light
                                by Bloopeta
                                Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                                Power button does nothing
                                Have unplugged the mainboard, and backlights illuminate.
                                Have tried removing panel ribbon cables one at a time, and that makes no change.
                                With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                                Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                                09-11-2023, 02:34 AM
                              • ChristianBr01
                                LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                by ChristianBr01
                                I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                04-23-2025, 01:48 AM
                              • Kaar3l
                                Samsung QLED QE65Q7FNAT only standby light
                                by Kaar3l
                                TV: Samsung QLED QE65Q7FNAT
                                PSU: BN4400940A
                                MB: BN94-12832K
                                I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                09-24-2024, 01:35 PM
                              • fuxxy
                                Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
                                by fuxxy
                                This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
                                Plug the set in, and it will turn on and functions with no issues.
                                After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
                                Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes...
                                08-02-2022, 09:44 AM
                              • marcinq
                                Samsung UE60KS7000 No Standby Light
                                by marcinq
                                I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
                                I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
                                05-26-2025, 11:36 AM
