LC70lE660U
    LC70lE660U
    I have this TV, standby light comes on with no display. standby lights blinks slowly. please help
    Re: LC70lE660U
    Hello!
    First round below, then later if there will be more information
    The supply voltages should be checked first.The following is based on the service manual should be checked
    Since the pins are monitored, this can also provide a starting point
    Pins are monitor microcomputer pins unless otherwise
    specified.
    1 flashes once Inverter/Lamp system failure
    2 Power PWB failure Flashes twice
    Flash once Power supply error AC_DET error
    Flash twice Power supply error UR+13.5V error
    Flash 3 times Power supply error D+3.3V error
    Flash 5 times Power supply error Panel power supply error
    Flash 6 times Power supply error power supply error
    Flash 7 times Power supply error power supply
    error
    3 Main PWB failure Communication failure,
    Flashes 3 times
    Flashes once Initial communication error
    Flashes twice Start-up confirmation communication error
    Flashes 3 times Regular communication error
    Flashes 5 times Other communication error
    4. VerUP executing Green flashes continuously. OFF Sub microcomputer version upgrading
    VerUP succeeded POWER (Green) and SLEEP/OPC flash alternately. Sub microcomputer version upgrade succeeded
    VerUP failed Green flashes fast. OFF Version upgrade failed
    ROM data failure Green flashes fast. OFF Start-up after failing version upgrade
    5 Pins are monitor microcomputer pins unless otherwise
    specified.
    Inverter/Lamp failure, details is detected.
    Flashes fast once
    H: On
    L: Off
    Power supply failure, details is detected.
    Flashes fast twice
    H: On
    L: Off
    Main CPU Communication failure, details is detected.
    Flashes fast 3 times
    H: On
    L: Off
    Other failure
    Communication failure details is detected.
    Flashes fast 4 times
    H: On
    L: Off
