Samsung plasma ps43d451 5 blinks
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Hi guys, ive been troubleshooting a samsung plasma tv. Ok heres the interesting part. relay clicks on, and off, 5 blinks thereafter and it recycles the same pattern.
    I have disconnected one by one
    Tcon
    X board
    y board
    Still same, 5 blinks. I checked all the voltages on power board, when it clicks all the voltages are accurate according to the specs then it disappears when it clicks off. Seems like ive done all the troubleshooting here and it all narrows to a main board. Anyone else had this problem before?
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Re: Samsung plasma ps43d451 5 blinks
    Ok heres another update: I tested only the power supply, shorted PS ON to Ground, Then checked all the voltages that goes to the main board, all good and accurate. Tested voltages to Tcon, all accurate.
    BUT, VA, VS voltage going to specified voltage upon turning on, then goes down fast. Is this normal without anything plugged in? Or it should be stable even with nothing plugged in?
    • DjKrish
      • Oct 2012
      • 354
      • SG
      Another quick update
      Ive kept the PS ON shorted to ground on PSU, plugged everything to power board except mainboard. Shorted pin 1 and 2 jumper on tcon for test pattern auto gain, walla. Theres test picture. Tested power supply voltage VS and VA, stable and all good. So this confirm main board faulty. Will update here once i replace the main board
      • DjKrish
        • Oct 2012
        • 354
        • SG
        Replaced main board, tv working perfectly now Hope this helps others as well to troubleshoot.
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • ohren
          Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
          by ohren
          I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
          I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
          The models launched in 2018 and 2019 respectively....
          09-08-2023, 05:24 PM
        • C152Heavy
          Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
          by C152Heavy
          Summary for TL-DR readers:
          • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
          • Have obtained Samsung schematic & service documents - Can upload if helpful.
          • Have read ALL applicable threads
          • C1818 and CP820 replaced as low hanging fruit
          • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
          • VCC pin (18) of PFC...
          01-11-2023, 02:53 PM
          09-07-2024, 05:50 AM
