Vestel 17IPS20 R9 Powersupply
  • thoma
    • Sep 2012
    • 268
  • psdavid65
    Toshiba 40L1333DEV Vestel 17IPS20
    by psdavid65
    Quick Question Please.
    Is low resistance on gate pin 5 of U202 normal? I have a very very low resistance of 5 ohm on this gate. In diode mode, it looks shorted and beeps. Is this a normal behavior of this FAN6300 IC?
    All other components on this vestel board have valid readings except for this U202 IC.
    09-21-2023, 12:29 PM
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
  • France_53
    Vestel tv, how to flip the image?
    by France_53
    Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
    05-12-2024, 05:22 AM
  • ray14324
    Telefunken LED TV with no standby linght equipped with Vestel 17IPS20 PSU
    by ray14324
    Searching the forum revealed loads of issues with this type of power supply board however I could not find a solution to my issue from them. Excuse the "another Vestel" thread
    The full story was: my Telefunken TV did not have a standby red light after of series of power outages in a couple of minutes. Sadly in my rural city the only technician that fixes TV's is away these days as I cannot reach him by phone. I want to try to have a go at it (with the internet's help).
    Reading into this symptom the general consensus was that...
    08-31-2021, 07:55 AM
  • worlor
    Bad Vestel 17IPS20 : shortage, need help
    by worlor
    My Vestel television has stopped working.
    After first diagnosys, the power board 17IPS20 R6 don't work (no 12V on output).
    I have replaced :
    • U300 FAN6300 -> completely blown up
    • Q301 MOSFET FQPF8N60C
    • C387 1uF Capacitor -> shorted
    • C295 & C296 1uF capacitor -> to be sure
    But with my multimeter, there is conductivity between VCC and GND on U300 and U202. I don't know why. Maybe a diode but i can't test these because of the short.
    Can you help me to find the cause of the shortage ? have you any ideas ?
    I attach...
    11-08-2020, 06:47 AM
