looking for vestel mb211s recovery firmware usb
  • petehall347
    • Jan 2015
    • 4423
    Re: looking for recovery firmware usb
    downloading first one now ..interesting thing when i point remote pressing a button and then plug into power first flash of standby light is double flash like its trying to do something .
    • Diah
      • Feb 2013
      • 6343
      BL come on to me there are other reason HW at MB make the set reboot again..
      • petehall347
        • Jan 2015
        • 4423
        yes i am thinking some hardware got damaged when he plugged the adaptor into hdmi .
        i did find i can make colour test bars using my finger on the solder pads by the lvds connector ..yes i know i shouldn't really be doing that but it says to me the panel is working .
        thinking i am going to have to turn the boards over and check voltages at the test points .
        • petehall347
          • Jan 2015
          • 4423
          just counted the flashes again and its either 8 or nine . hard to tell .. on the last flash a white horizontal short thin line flashes on the screen . this is random where it is for each power on . its like something tries to start then trips before it can do . might be wrong but it does it anyway .
          • raileanu
            • Sep 2015
            • 126
            I also need the full Installation USB files please. Can't find anywhere.
            • iuliantv
              • Aug 2009
              • 35
              #26
              Re: looking for vestel mb211s recovery firmware usb
              https://easyupload.io/y7z9nv
              • raileanu
                • Sep 2015
                • 126
                #27
                Originally posted by iuliantv
                Thank You !
                Multumesc Iulian !
                • eddiesomesan
                  • Feb 2011
                  #28
                  Could you please reupload? The files are not found. Thank you.
                  Multumesc.
                  • Tommes
                    Telefunken D43F287N4CWII - Vestel 17MB110S - Recovery Firmware
                    by Tommes
                    Hey Folks,
                    I'm searching for a Full Flash Recovery Software
                    for my Telefunken D43F287N4CWII
                    Mainboard Vestel 17MB110S
                    Panel: VES430UNDB-2D-N12
                    Productcode: 10119394
                    Does anyone know, where I can get it ?
                    Or is it possible, to extract it from a working mainboard ?
                    The Support Telefunken/Vestel GER couldn't help me.
                    The Vestel TR Support didn't answer my email.
                    History:
                    The main problem with my Telefunken D43F287N4CWII was,
                    it just goes out after a while, sometimes after a...
                    01-04-2022, 09:56 AM
                  • massimomax
                    Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
                    by massimomax
                    Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
                    spero che qualcuno può averlo per riprogrammare eprom. grazie
                    Post in English !!!
                    I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
                    02-28-2025, 07:27 AM
                  • anlu
                    Vestel Firmware - Toshiba 32W133DN
                    by anlu
                    Hello, i have an old Toshiba 32W1333DN (sorry, misspelled the headline) TV that had the standby led green/red flashing and no lightup problem, i repaired it by measure the led output as suspect led problem, i measured the LED:s one by one and found one bad led, i replaced the the led-straps and the TV works.
                    Now i need to update the software because the new rc "RM-L890" does not work and i think maybe it could be an firmware issue?, i have struggled to find it without any success because all of the links where invalid, i contacted Toshiba but they do not support this model...
                    02-04-2023, 12:59 AM
                  • piernov
                    Finlux 65-FUC-8060 firmware request (Vestel 17MB130S 23473048 VES650QNTS-2D-U11)
                    by piernov
                    Got a Finlux 65-FUC-8060 TV that doesn't turn on, 5V standby present from PSU, 3.3V on mainboard present, button signal gets pulled low when pressed, but mainboard never sends signal to PSU to turn main rails on.
                    I suspect corrupt firmware but I haven't been able to find anything for this TV.
                    TV model: Finlux 65-FUC-8060
                    Mainboard: Vestel 17MB130S 23473048
                    Panel: VES650QNTS-2D-U11
                    At the very least looking for a firmware that can make it turn on to confirm the problem, and hopefully a firmware that's compatible with the panel.
                    06-01-2024, 12:57 PM
                  • TheUser
                    Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                    by TheUser
                    Hello to everyone ,
                    This is my first post here, and i would like to share with you a small story in case you can help me.
                    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                    02-10-2024, 02:07 PM
