Philips 47PFL4606 No Power Fuse Keeps Blowing
    replied
    Re: Philips 47PFL4606 No Power Fuse Keeps Blowing
    BTW, you did not change any transformer on this 47" board we are working on, correct?
    replied
    It is not PFC problem, it is the low voltage (10V) we are getting from the AUX winding of the 5VSTBY power supply transformer, we need to get about 15V form it but we are not getting it. we need 15V on C846 first, that is what we trying to figure out why we are only getting 10V.
    We know that the good 47" board was putting out 15V but we do not have that good board anymore to do comparison testing.
    So do not do anything in the PFC or SMPS section.
  • trunks81
    replied
    What sections can i check more to find an error in the pfc ?
    replied
    Originally posted by trunks81
    That correct it is 230V and when i measure it is 230 exactly
    Iam trying to learn how to read schematic i understand a little but still not enough
    OK, that explain why you did not understand what Voltage you should get and why.
    At this we cannot use the 37" board as a good board since the VCC Voltage is too low to run PFC and the SMPS IC's.
    We need to get hat 10V up 15V first but I do not know yet why it is not working when the 5V output is correct at 5V when 1K is present.
    So are you going to return that defective 37" board?
  • trunks81
    replied
    replied
    I updated my reply.
    The cause of both board not working is due to low voltage on C946.
    So the seller of the 37" board sold you bad board.
  • trunks81
    replied
    Hello Budm
    Oke good to know need to find out then what is causing it!
    what else can i check ?
    What section in the schematics is the PFC Booster circuit ?
    replied
    Ive got 311V on Filter cap of the 37 inch with 1K in place. (Strange when i place this board back into the tv ive got 300V on the filtercap and 14,6V on C946 tv is running only backlight is flickering)
    Also gor 311 on the filter cap of 47 inch
    That means the PFC Booster circuit is not working on both boards! That 37" board is not fixed.
    The Voltage on the main filter cap should be around 380 ~ 400V when PFC is working.
    The schematic shows 395V.
    The inverter circuit will not work properly at 311V, it should not even come on if it has low Voltage protection circuit.
    BTW, is your AC Voltage is 230VAC? Measure it.if it is 230VAC, then the Voltage on the cap should be around 325VDC when in standby.
    BTW, you do know how to read schematic, correct?
  • ivtec
    replied
    Flickering maybe bad caps on
    inverter board.
  • trunks81
    replied
    replied
    C946 = 8.15v / 9.8v (37)
    c946 = 7.8v / 10.5v (47)
    The 37: board is actually working with that low Voltages, 9.8V? 9.8 is not enough to run the PFC and the SMPS IC.
    That does not look right at all.
    What DC Voltage (measured between the two legs of the cap) do you get on the main filter cap of the 37" board with 1K in place?
    The picture attached is from your working 47" board.
  • trunks81
    replied
  • trunks81
    replied
    replied
    We know that we have those Voltages at Q907 (or C946), we need to find out why the Voltage generated by the 5VSTBY transformer is so low, it should be closed to 15V like we had in other thread, that is what we need to figure out.
    Right now 10V to too low to run t he PFC IC and the 12V/24V SMPS IC.
    If you check the Voltage on your 37", you will see that it is higher than this 47" board we are working on.
    We know that the 5V output is OK, we have 5V when 1K is connected but we do not have the 15V from AUX winding when 1K is connected, something is loading down this Voltage. We need to get correct Voltage at this section first before working in the PFC and the 12V/24V section.
    Check the Voltage of Q907 (or C946) on your 37" board with and without 1K and see what you get.
  • trunks81
    replied
    Hello Budm
    My measuments of Q907
    https://www.badcaps.net/forum/attach...1&d=1596089841
    replied
    BTW, we still need to find out why we only have about 10V on C946 when 1K pull up is connected, the PFC IC FAN6961 and SMPS ICNCP1271 need 12.5V for the circuit to start running.
    We know that IT should have about 15V based on the board that we fixed for 47" in the link below.
    https://www.badcaps.net/forum/showthread.php?t=86061
    https://www.badcaps.net/forum/attach...6&d=1594984130
    So we need to figure out why we are only getting around 10V.
    replied
    Yes the (good) board (37 inch) is partially working problem now is that the CCFL are flickering but the board gives an 5/12/24V and the tv starts
    Both pictures show R916 markings of 4R7, so I do not understand by the reading of the good board is over 100K that you reported "R916 reads 123K ohm and reverse 133K ohm" on the 37" good board.
  • trunks81
    replied
    replied
    Q907 is changed and the measurements in previous post where with an 1K in place
    Q907 = 9,8 to 10.5V on all the legs to hot ground
    4. R929 is damaged getting an reading of 28/k ohm and reverse 8.2K ohm
    Soldered R929 out of the pcb and now its reading 47K ohm
    5. R916 reads 123K ohm and reverse 133K ohm !! the bad board reads 4.7 ohm in both directions
    4) Since R929 reads 47K as it should be then it was not damaged.
    5) R916 is part of the Gate drive circuit for MOSFET Q902, the circuit will not work with that high if the resistance present on the Gate drive circuit OF THE GOOD BOARD. Can I see the picture of the good board and the bad board around the resistor and Q902? Are you sure you good board is good?
  • trunks81
    replied
  • Dannyx
    UC3842 Power Adapter Blowing Fuse
    by Dannyx
    Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
    Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
    12-05-2023, 12:06 PM
  • Tips
    Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
    by Tips
    Looking for some assistance please.
    Trying to repair a PD27AOQ samsung power board.
    Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
    Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
    Testing it the fuse blows immediately power is turned on.
    diodes dm852 and dm853 test as shorted when in the board but fine when removed.
    any assistance, guidance would be appreciated.
    04-11-2024, 11:24 AM
  • RogerH58
    Samsung 46" TV LE46B530 blowing fuse
    by RogerH58
    I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
    I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
    I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
    06-10-2023, 10:27 AM
  • corrize
    A funny fuse story – Lumix LX100 II
    by corrize
    Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
    I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
    The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
    There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
    And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
    10-19-2023, 09:58 AM
  • simwalsh
    Philips 47PFL4606 Powers on, works normal then powers off after a minute
    by simwalsh
    I am new to this forum and have searched for some answers with problems similar to mine.
    Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
    It sounds like a power supply issue?
    I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
    12-04-2023, 04:03 AM
