Philips 47PFL4606 No Power Fuse Keeps Blowing
  • trunks81
    • May 2020
    • 265
    • Nederland
    Re: Philips 47PFL4606 No Power Fuse Keeps Blowing
    Hello Budm
    1. On C946 i get 0.7V ?! seems low to me !
    2. Between pin 3 and 4 i get 4,7V
    3. Between pin 1 and 2 i get 0.85V
    4. C943 is 21.32uF and 1.05 ohm
    5. its really an other board and tv !
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Those results don't seem right. C946 is connected to the Opto isolator (IC907) which has 4.7V across it. It can only get that voltage from D916/C916 which you say is at 0.7V
      • trunks81
        • May 2020
        • 265
        • Nederland
        The voltage across D916 is 0.7v and C916 0.3V
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          The voltage on Pin 3 (Control) of the TOP264 should rise to 5.8V. The capacitor connected to this pin is charged up by the voltage on pin 6 (Drain). When it reaches 5.8V the internal circuit providing the charging current from the Drain supply to the capacitor switches off and the voltage across the capacitor connected to Pin 3 is then maintained by the feedback winding of T904
          Can you check that the voltage on Pin 3 rises to 5.8V
          • trunks81
            • May 2020
            • 265
            • Nederland
            The voltage on pin 3 rises to 5.5V of TOP264 !
            No difference when 1k resistor in place
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              #26
              So at switch on it rises to 5.5V and stays at that voltage?
              The data sheet says the initial operating voltage needs to reach 5.8V on the Control pin before the mosfet kicks in and drive the transformer so long as the Control voltage doesn't drop below 4.8.V
                "When i measure the 5V its only 2.7V, When i connect an 1K to S/B-5V iam getting 1.9V on the 5V"
                I am confused as to why you are getting Voltage on the cold side of the 5VSTBY power supply but you report this in post #21 "1. On C946 i get 0.7V ?! seems low to me !". C946 which is the filter cap for the rectifier D916 which rectifies the AC from the AUX winding of the STBY transformer T904, having 0.7V on that filter cap means the transformer AUX winding is bad or R959 (4R7 Ohms) is open. The Voltage on that C946 should be around 15V (see your thread of the same TV on another thread) when PS-ON is present, and lower when PS-ON is not present. If you look at the other thread, you will see that you will have around 4.6V output on the 5VSTBY pin, then it will jump up to 5V when PS-ON is present.
                The 15V ON C946 is used for runninng the SMPS ic's and PFC IC
                BTW, post 22 by dick_barton
                "Those results don't seem right. C946 is connected to the Opto isolator (IC907) which has 4.7V across it. It can only get that voltage from D916/C916 which you say is at 0.7V"
                I think he means C946.
                Bottom line, you need to check the Voltage on C946 again.
                • trunks81
                  • May 2020
                  • 265
                  • Nederland
                  #28
                  Hello
                  C946 = still reads 0.75V,
                  T904 = Measured along with the 37inch board and reads the same!
                  R953 = 100 ohm
                  C952 = 100.2 nf
                  R956 ,R954 ,R957 ,Q908 ,R952 = Compared them with an other board and they both read the same
                    Originally posted by trunks81
                    Hello
                    R953 = 100 ohm
                    C952 = 100.2 nf
                    37"?
                    We worked on the 47" same model on this Thread: https://www.badcaps.net/forum/showthread.php?t=85971
                    • trunks81
                      • May 2020
                      • 265
                      • Nederland
                      #30
                      Hello
                      I have two 47 inch and one 37 inch, The fixed 47 inch is gone now,
                      And the 37inch board is almost exact the same as the 47 inch except for the CCFL part
                      So i did compare it with that board. Also the 47inch tv starts with the 37inch board only no BL
                        Where is the link to show me the power supply board of the 37"?
                        This one, correct?
                        https://www.badcaps.net/forum/showthread.php?t=85509
                        That 37" board is still not fixed, correct?
                        That 37" board standby power supply is working, correct? So what Voltage do you have on C946 (no need to use resistor to turn on the power supply), just power up the board by itself.
                        • trunks81
                          • May 2020
                          • 265
                          • Nederland
                          #32
                          On that board i have 8,1V on C946,
                          also
                          The voltage on pin 3 rises to 5.9V of TOP264 !
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            #33
                            If you have twp identical boards, one working and one not working perhaps you could give the voltage readings of each around IC905, IC907 & C946/D146 junction.
                            Also can you use your meter set to ohms to compare resistance readings against each other at the above points.
                            • trunks81
                              • May 2020
                              • 265
                              • Nederland
                              #34
                              Hello
                              Tested the two boards across. and came to the next result
                              Color green is for working board and red for the not working
                              All is tested without the 1K resistor
                              IC905
                              1= 2.85V 1.30V
                              2= 1.3V 1.26V
                              3= 5.92V 5.5V
                              4= 0V 0V
                              5= 317V 315V
                              IC907
                              1-2 = 1.10V 0.31V
                              3-4 = 2.21V 4.80V
                              C946 = 8.16V 0.70V
                              D916 = 8.22V 0.70V
                              • dick_barton
                                • Aug 2015
                                • 6642
                                • Wales
                                #35
                                IC905 Pin2 is 13V or 1.3V for the working board???
                                Looking through threads on this power supply and the problem tends to be either IC905 or ZD907.
                                • trunks81
                                  • May 2020
                                  • 265
                                  • Nederland
                                  #36
                                  Sorry Typo its is 1.3V
                                  Changed IC905 and ZD907 and still the same results
                                  • dick_barton
                                    • Aug 2015
                                    • 6642
                                    • Wales
                                    #37
                                    The voltages for IC905 are not too dissimilar to your test board. They will be for the Opt since there is no 5V on the secondary.
                                    Check the solder joints on IC905 since I feel that this is where the fault lies.
                                    Can you measure the resistance to hot ground of all the pins of IC905 between the good/bad board, power off.
                                    • trunks81
                                      • May 2020
                                      • 265
                                      • Nederland
                                      #38
                                      Got the next
                                      IC905 to hot ground both boards measure almost the same
                                      1 = 9.595k 1 = 9.677k
                                      2 = 10.346k 2 = 10.416k
                                      3 = 6.620k 3 = 6.744k
                                      4 = 0.11ohm 4 = 0.10ohm
                                      5 = 2.7271k 5 = 2.7436k
                                      • dick_barton
                                        • Aug 2015
                                        • 6642
                                        • Wales
                                        #39
                                        Other than changing IC905 once more I can't see what else there is to check.
                                        You have definately checked R959 and replaced D907 with a 9.1V zener diode.
                                        One side of R959 to hot ground should measure 4.7 ohms (plus winding resistance) and the other side of R959 should measure just the winding resistance. This will eliminate the transformer winding as a problem.
                                        Was IC905 replacement a new device, Chinese purchase or from a donar board?
                                        • trunks81
                                          • May 2020
                                          • 265
                                          • Nederland
                                          #40
                                          IC905 was an new unit.. which came from ebay, So probably from china ?
                                          https://www.ebay.com/itm/3pcs-T0P264...53.m2749.l2649
                                          When i measure R959 on both boards iam getting on one side 5.11ohm and the other side 0.15ohm
                                          Ordered the TOP264 at farnell (Sinuss) now and ill see if that fix the problem
                                          EDit used the top264 form the working board and no difference
                                          • Dannyx
                                            UC3842 Power Adapter Blowing Fuse
                                            by Dannyx
                                            Good day folks......wow this new layout is weird. It's like I woke up one day and I'm no longer on Planet Earth or something
                                            Anyway....got this here power brick from a USB to SATA adapter which keeps blowing the fuse after I almost repaired it. The reason I even bother to fix a power brick (wall wart, whatever) in the first place is because this thing was really convenient to use: I'd just plug it and that's it. It's a dual output supply, for both 12v and 5v, which although I COULD easily obtain with a DC-DC converter from a standard 12v adapter, I thought I should crack open the...
                                            12-05-2023, 12:06 PM
                                          • Tips
                                            Samsung PD27AOQ (BN44-00506B) constantly blowing internal fuse.
                                            by Tips
                                            Looking for some assistance please.
                                            Trying to repair a PD27AOQ samsung power board.
                                            Initially had the typical problem of cm806 capacitor blown, additionally thermistor NT801s blown.
                                            Replaced the ceramic capacitor, str60252s, bridge rectifier, thermistor and fuse.
                                            Testing it the fuse blows immediately power is turned on.
                                            diodes dm852 and dm853 test as shorted when in the board but fine when removed.
                                            any assistance, guidance would be appreciated.
                                            04-11-2024, 11:24 AM
                                          • RogerH58
                                            Samsung 46" TV LE46B530 blowing fuse
                                            by RogerH58
                                            I am a newbie and not very experienced so bear with me if i struggle sometimes with technical language - but I'll do my best. I searched "Samsung" and the model number on the forum but didn't find anything I could understand!
                                            I'm not an electronics guy - just picked up stuff over the years through my flight-simming hobby.
                                            I have the above mentioned 46" tv as the monitor for my flight-sim setup. Recently it went "crack" and stopped working. No standdby light and no response. I assumed a fuse had blown and after investigation...
                                            06-10-2023, 10:27 AM
                                          • corrize
                                            A funny fuse story – Lumix LX100 II
                                            by corrize
                                            Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                                            I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                                            The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                                            There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                                            And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                                            10-19-2023, 09:58 AM
                                          • simwalsh
                                            Philips 47PFL4606 Powers on, works normal then powers off after a minute
                                            by simwalsh
                                            I am new to this forum and have searched for some answers with problems similar to mine.
                                            Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                                            It sounds like a power supply issue?
                                            I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                                            12-04-2023, 04:03 AM
