Bad T-con or bad panel??
  • Alternet
    • Oct 2017
    • 41
    • canada
    #41
    Re: Bad T-con or bad panel??
    Originally posted by Diah
    this is yours when i wrote about tape...
    and this bellow now the same way you are attacks some one like to help..
    you shared your problem over this forum.. and many users over here like to help and they did by sharing their experiences and KNOW HOW.. not to put you at experimentation process.
    if this doesn't suit you then do what ever you like. good luck
    I'm not trying to attack you at all. Please dont take it that way. I was actually hoping you had a schematic. I was going to ask if you could send me a copy.
    I was in no way trying to attack you. I'm sorry that it came across that way.
    • neilc6
      • Nov 2015
      • 1550
      If the TV has tabs on the bad side, rip them off.
      • nomoresonys
        • 12229
        • U.S.
        #43
        Well your latest picture looks like what I've seen many times but doesn't have to be, it looks like you have a bad tab bond connection on that side. If it is some have had good luck with "shimming", there's quite a few videos on youtube covering the technique.
        ps, Please don't attack me.
        • Alternet
          • Oct 2017
          • 41
          • canada
          #44
          Just want to make sure i know what your talking about. By tabs are you referring to what I have circled in red in the attached picture.
          Also i'm still not quite sure what to make of the spot pointed to by the green arrow. Is this damage from a short or is this common to see in these panels? (as I said before I do not have much experience with lcd panels)
          • nomoresonys
            • 12229
            • U.S.
            #45
            That's a good picture, it's so close up I can't tell, is it on top bottom or side, can you show more pictures maybe not so close up?
            • Diah
              • Feb 2013
              • 6424
              its Normal at the rand, out side the display area..
              • Alternet
                • Oct 2017
                • 41
                • canada
                #47
                that is the lower left side (if looking from the back of the display). I don't have any other pictures right now. I can take some when i'm home tonight if that will help.
                is that what you mean by tab? or do you mean the ribbons connecting the panel drivers to the panel?
                • Diah
                  • Feb 2013
                  • 6424
                  Man, this set you had never saw picture on it before replacing BL, so theory when you repaired the BL you got short at ribbon or sockets.. after you played with tape trick some how the short are gone. to verify this theory now if you remove the ribbon only from T_CON side of the effect side you will have white clear half picture not as before you showed us.. do it and let us focus on the real issue.
                  • nomoresonys
                    • 12229
                    • U.S.
                    #49
                    Yep, do diah's test again, see what you get.
                    • Alternet
                      • Oct 2017
                      • 41
                      • canada
                      #50
                      I think I might have been wrong on saying I never saw a picture. In my original post about the back lights I did say I saw the LG logo pop up for a minute. I honestly cant remember now if I did or not. But my post says I did so i have to assume the panel was able to display picture at one point and that i just couldn't see it because the backlight was dead.
                      Are you wanting me to disconnect the LVDS cable from the tcon or just the ribbon cables to the panel driver boards? (I cant do it right now but i will do it tonight and take a picture)
                      • nomoresonys
                        • 12229
                        • U.S.
                        #51
                        Just the ribbons one at a time like you did before.
                        • Diah
                          • Feb 2013
                          • 6424
                          not LVDS... only the ribbon cable between effected side and panel... just remove it out from T-CON socket side... don't touch any ribbon now at the panel socket side
                          • nomoresonys
                            • 12229
                            • U.S.
                            #53
                            Right you already know which side is bad.
                            • Alternet
                              • Oct 2017
                              • 41
                              • canada
                              #54
                              Ok i just want to clarify again.
                              so for the test you want me disconnect both ribbons from the t-con side (not at the same time) and verify that side goes white and the other has picture.
                              Also i don't know if this is useful info in anyway but when doing the tap method i was taping on the t-con side of the ribbon cable
                              • Diah
                                • Feb 2013
                                • 6424
                                LOL... ONLY the dark side, remove the ribbon of it from T-CON Socket.. and upload photo here... other sockets don't touch at all
                                • Diah
                                  • Feb 2013
                                  • 6424
                                  nomoresonys HELP... i am not native English speaker or writer..
                                  • Alternet
                                    • Oct 2017
                                    • 41
                                    • canada
                                    #57
                                    Ok well the dark side is the side that use to be the issue.
                                    i did disconnect that side several times after it just started working again for no reason. I get a fully white screen on the "dark side" and a picture on the "good side"
                                    I will do it again tonight and take pictures.
                                    • nomoresonys
                                      • 12229
                                      • U.S.
                                      #58
                                      Ok, well that I think is normal, now try the other side if you get half a good picture with no distortion with each ribbon removed, then maybe it's not a panel issue.
                                      • nomoresonys
                                        • 12229
                                        • U.S.
                                        #59
                                        Yes taping on tcon side is fine.
                                        • nomoresonys
                                          • 12229
                                          • U.S.
                                          #60
                                          Could it be a tcon issue? starting to wonder.
                                          • kca
                                            by kca
                                            Hello all ~
                                            08-31-2025, 06:38 AM
                                          • NWArkGuy
                                            Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                            by NWArkGuy
                                            Well, I will be the first to admit that I screwed up...
                                            In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                            I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                            I have 2 that I have found and have in my possession. ...
                                            10-12-2023, 10:13 PM
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
