LG 60UF7300-UT issue
  • Rmasters3
    • Mar 2010
    • 126
    No audio and unit will not show video except the brief Channel information in upper left corner.
    Have done no diagnostic yet, but apparently LG had mainboard issues with solder joints. There's one guy on Youtube showing how you heat the motherboard in an oven to 385 for 10 minutes and this causes the solder to flow and correct the problem. Any input, before I try and roast my MB?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: LG 60UF7300-UT issue
    385f won't cause lead free solder to flow.
    • Diah
      • Feb 2013
      • 6439
      showing channel info only with out broadcast picture or audio almost "IN_STOP" reset could solve it in case the signal of source strong.
      • Hamie
        • Apr 2014
        • 1383
        Why would in stop fix this?
        • Diah
          • Feb 2013
          • 6439
          it looks the Tuner Hardware register missing or changed at the firmware.. same if some one change the code of it at service A_Z Adjust menu, it will not catch signal.... if no one change it then In_stop will write back the original one.
          to approve this the set could have picture and audio if OP feed it with HDMI signal or USB media content,, before he go to cooking it.
          • Rmasters3
            • Mar 2010
            • 126
            Anyone suggest something a relative novice like myself can attempt?
            • neilc6
              • Nov 2015
              • 1550
              Audio only goes through the main board (as long as the power is present and stable) so is your main suspect. For a novice, replacing it is the easiest option. In stop is a service remote command to perform a factory reset. You will either need as service remote or a smartphone with IR so you can download a LG remote app.
              • Diah
                • Feb 2013
                • 6439
                simple way use another input source on yours tv such HDMI signal and check do you have picture and audio ( i guess yes ) ...
                also if you press the menu or setting on remote control did you get the menu on screen.. ( i guess yes )
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4465
                  • Italy - Milan
                  Hi, i'm fighting with a LG led tv smart 3d that doesn't show other inputs than aerial, i bet yours 90% is bad cpu soldering, it is a constant with LG led tvs, mine is 100% , the cases are growing every day, i'm not sure if it is a tin fact or a thermal pad very poor.. almost no need to formulate diagnosis, a won bet..
                  PS: it's fool to cook it in oven dry as it is.. a giant tv needs a better treatment like a sending repair work by pro reballing service.. and after this... new heat conductive stuff like cream and a temp conttrolled fan. +cream change every 2 years.. and better stop append tvs to the wall like an artwork, they don't breathe..
                  • Nick's Tvs
                    • Jan 2014
                    • 621
                    Unfortunately with these boards the issue is not with the solder but the BGA chip itself. The chip itself is defective and needs to be replaced. Putting your board in the oven can will not fix this. If you can replace the large BGA at the top left corner of the main board, then you have a good chance of fixing your issue.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4465
                      • Italy - Milan
                      I can't image how a bad processor can work normally in the.software basis standing on what shows the pictures, that shows a normal graphic layer, the messed up DTV is due to bad contacts berween cpu<>tuner or cpu<>ram.
                      • handsworth
                        • Oct 2015
                        • 174
                        Lg's UF series sucks. That BGA chip will fail almost 100%. Best bet is to get somebody to reball it with some kind of warranty.
                        • Mirenia
                          Acer Helios 500 (PH517-51) - unexpected reboots when laptop is warm (cold solder joint issue?)
                          by Mirenia
                          got an Acer Helios 500 Laptop (PH517-51) for diagnosing with a strange issue:
                          The laptop runs for a while (1-2 hours, sometimes less) and then suddenly shuts completely off, like someone pulled the power cord and restarts immediately after on its own.
                          If this happened once, then the laptop only runs for a few minutes until restart.
                          This happens regardless while staying in windows or uefi or in a linux environment.
                          At first I thought of a normal overheating issue, but as I monitored temps with HWInfo64, nothing seems very hot.
                          01-05-2025, 05:15 PM
                          ASUS ROG FLOW-X13-GV301RE-007W Hybrid (2-in-1) Flow X13 Specification for Upgrade or Repair
                          This specification for the ASUS ROG FLOW-X13-GV301RE-007W Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FLOW-X13-GV301RE-007W boardview and FLOW-X13-GV301RE-007W schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                          09-07-2024, 06:40 AM
                        • rounin
                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                          by rounin
                          🛠 Original Issue
                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                          04-19-2025, 01:18 AM
                        • ugamazing
                          by ugamazing
                          12-17-2024, 07:05 PM
                        • corrize
                          Best way to solder LVDS connector for beginner (and qfn) ?
                          by corrize
                          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                          See the test :
                          https://youtu.be/bNAzC-EvqHs?t=1767
                          With hot air from bellow the board, that's...
                          03-09-2023, 02:57 AM
