N75UX17A-AU T-COn board issue?
  • RooTV
    • Apr 2020
    • 128
    would I be right in thinking this may be a tcon board issue?
    Its a Soniq N75UX17A
    All I have is this picture and the guy said that he bought it yesterday but something must have happened in transit.
    Not sure if thats screen damage in the middle bottom or not?
    update.
    got a close up photo of the mark in the middle bottom of the screen.
    Looks like panel damage to me. I have told him it is unfixable and only good for parts unfortunately
    I have included the photo. what do you think?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: N75UX17A-AU T-COn board issue?
    Obvious panel damage.
      • 12276
      • U.S.
      AND NOW a double thread?????????????? 2 threads to ask the same question about the same tv, started 30 minutes apart on a Sunday morning...what's the matter are we not answering fast enough for you????????
        and now a double thread?????????????? 2 threads to ask the same question about the same tv, started 30 minutes apart on a sunday morning...what's the matter are we not answering fast enough for you????????
        +1
        • RooTV
          • Apr 2020
          • 128
          I am so sorry. I didnt even know I had done it.
          I was editing the original thread to add/change photos and I must have created the second one by mistake.
          It wasnt intentional.
          • Soulzink
            Samsug washing machine. Power supply DC41-00189a board issue
            by Soulzink
            I am trying to fix a samsung washinmachine power supply main board.
            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
            The power supply board reference is the following: DC41-00189a
            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
            04-19-2025, 06:26 AM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • Asraf Atb
            by Asraf Atb
            01-27-2025, 05:02 PM
          • Stephen
            A2991 Logic Board issue, 20volts 0 amps help!
            by Stephen
            Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
            09-10-2025, 03:16 PM
          • Stephen
            A2991 logic board issue, 20volts 0 amps help!
            by Stephen
            09-10-2025, 03:15 PM
