Philips 40PFL9705 T-con 9 blinks
  • trunks81
    • May 2020
    • 265
    • Nederland
    Re: Philips 40PFL9705 T-con 9 blinks
    should i use IRF8734PBF for both fets ?
    Where can i get those fets ?
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4459
      • Italy - Milan
      Only the FDS 8813NZ as i've said, the other one usually don't fails so replace the original one.. i have named 3 popular sites for components, i don't know which are in your country, make a search, here there is also Distrelec.
      • thommyX
        • Apr 2016
        • 94
        ASWO Service Nederland BV
        • William1967
          • Nov 2017
          • 215
          • Netherlands
          Aswo only sells to companies with a Chamber of Commerce registration aimed at electronics.
          • trunks81
            • May 2020
            • 265
            • Nederland
            okay i replaced the fets again by an new set i received today.. and the tv is working for an short moment! in the begining ive got a full screen image and now the image is like this
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4459
              • Italy - Milan
              #26
              it.seems that you have conected bad the output flat cables.. clean them and re insert..
              • trunks81
                • May 2020
                • 265
                • Nederland
                #27
                Strange thing is when no source is connected ive got good image.
                When i connect mine Chromecast this happens
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4459
                  • Italy - Milan
                  #28
                  1. Are you repairing the original tcon or the Chinese one?
                  2. Have you ever made an attempt to reflow one of the processors that ThommyX says?
                  • trunks81
                    • May 2020
                    • 265
                    • Nederland
                    #29
                    The orginal one keeps giving me error 9, allready changed both fets same result.
                    On the chinese one i did an reflow of the bad side
                    • thommyX
                      • Apr 2016
                      • 94
                      I'd like to report a result, but I'm still waiting for some parts from China. I only order mosfets, ic's, transistors from ASWO.de. Unfortunately, they don't have the accessories. I am registered there through my company. Unfortunately the Tcon is no longer there and so I try to repair it because I know that the circuit boards from China always cause problems.
                      LG Thomas
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4459
                        • Italy - Milan
                        #31
                        Trunk i understand almost nothing if you don't report things in a clear way.
                        • kca
                          by kca
                          Hello all ~
                          08-31-2025, 06:38 AM
                        • x_orange90_x
                          TCL 50S535 bad tcon or panel issue?
                          by x_orange90_x
                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                          03-29-2025, 11:02 PM
                        • advant
                          by advant
                          02-03-2020, 12:25 AM
                        • Hakuu
                          by Hakuu
                          Hi There,
                          More Details
                          TV Model - LG OLED77G1PUA
                          07-12-2023, 02:37 PM
                        • Biruslapio
                          Panasonic P58V11B 8 and 12 blinks error "fix"
                          by Biruslapio
                          Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                          Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                          04-13-2021, 07:13 AM
