TCL Model 55S405 - No Pic, No Backlight, No Sound - HELP!!!
Re: TCL Model 55S405 - No Pic, No Backlight, No Sound - HELP!!!
Probably a pretty good tv you have there, probably just a matter of what's wrong with it, which may be found with proper testing but it's work and not always easy if inexperienced with electronics.Comment
The tv itself is enticing me to keep it to fix it. The only drivers keeping me from embracing it fully are the viewing angle which gets cloudy and the low brightness level. I want a bright tv not one where I have to struggle to make out images. But if you think these factors are mitigating let me know.
Looks like budman is busy working today. Hope he reads this today and get his input.
.Comment
If you got a meter working properly, try the tests in post #20, they're pretty simple, the test is on the cold side of powerboard, the HOT/PRIMARY side is the side with the DEADLY VOLTAGES and you MUST be very careful when working in that area, number 2 below shows a video tutorial.Comment
I'm waiting for your test result in my post #20.
Did you read it and understand it?
Did you verify that the meter is good for sure at this point?Never stop learning
Well I was referring to the panel sticker info, which is on the back metal chassis of tv on a sticker, you need to take the back cover off to access it, guess you could see if there is a service code number on the back cover, might start with srv code or sum such.Comment
Thats too much work for the person who owns that tv.Comment
Figured it would be because you said they were old, there are 2 suggestions there, the other is just look at the back cover without removing and see if there is a service code number, other than that, I don't know.Last edited by nomoresonys; 07-08-2020, 09:38 AM.Comment
Hi nomoresonys.. when you say to "look at the back cover without removing" do you mean the stickers on the back of the tv that contain info like serial number?Comment
So where is the follow-up?Never stop learning
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by nickgronkJust picked up an iMac powerpc for $1 at auction. changed pram. This is working. Problem, barely any sound. I have everything cranked up in software, reset nvram/pram - nada. I do get sound ONLY if I plug in a powered speakers in headphone port. I do not get the startup bong.
I get almost no sound with normal headphones. I mean, you can barely hear it. Took the board out and by eye found these 2 inductors broken. Not sure if they are for sound. Speaker is also plugged in and I tried a normal pc speaker in its place - still zilch. Are these inductors the culprit?
I cannot find any schematics... -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... - Loading...
